Creaking Cranks
[Closed] Creaking Cranks
[#3824453]
I have a set of Race Face Deus cranks. The cranks creak when under power. Could anyone advise how to stop this?
I have changed the bottom bracket, swapped pedals and it happens on all 3 chain rings so I am confident that it is a crank issue not some other component.
Help would be gratefully appreciated.
Posted : 30/03/2012 11:19 pm
Did you put grease on the bb spindle and the pedal threads before you put them together?
Posted : 30/03/2012 11:27 pm
Check the chainring bolts and grease. Also check your seatpost and grease.
Posted : 31/03/2012 9:23 am
If you have an integrated headset, check the bearings aren't shifting in the frame slightly and grease or studlock. I wrongly went through 3 combinations of cranks and bb's before I solved the creak.
Posted : 31/03/2012 9:29 am
I had this with my race face respond cranks, it was driving me mad. Swapped out bb and tried different pedals but still there. I then gave the left crank arm a yank and heard the same noise.
Once I'd taken it off it was obvious that it was the spindle. Applied grease and since then the problem has gone away.
Posted : 31/03/2012 9:31 am
Also, as no one else has pointed out yet- check for cracks. Everywhere.
Frame, cranks, seatpost etc.
Creaks are amplified by the frame and can sound like they are coming from somewhere else!
Also check your crank bolts are tight. Grease them nicely.
Posted : 31/03/2012 10:19 am
Thanks for all the advice. I will get greasing!
Posted : 03/04/2012 11:05 pm
Seatpost, saddle rails and make sure back wheel qr is tight(if you have qr that is)
Posted : 04/04/2012 9:04 am
