I've searched already but am getting more confused by the day with spacers, chainring bolts etc etc. Could someone do an idiots guide for me please?
I have a Cotic Soul Frame arriving soon and would like to use my Shimano XT cranks. They are M785 2x10 specific ones but I would like to go 1x10.
I guess I remove the granny, rather than the outer ring but do i need to modify anything else? Use spacers, cut of lugs, use longer bolts?
Many thanks for any input.
Use a ring where the outer one currently is. You may want to go to a single ring specific ring - have a look at Hope.
No spacers or anything required.
Outstanding. Many thanks indeed.
Are you planning a chain device of some sort too? I just converted an M785 triple to 1x10 with an MRP G2 mini... slightly different in that for me it's the middle ring being replaced but it got a bit complicated with bolt lengths and stuff (needed shorter lugs).
Was thinking of putting one of those Bionicons on there.
You should be alright then I guess, so long as it keeps the thing on well enough.
