Converting Dual pos...
[Closed] Converting Dual position Lyric to solo air
[#10205071]
Hi all,
i have a pair of dual position 2017 Lyric forks I would like ideally switching to solo air.  Is it just a case of swapping air shaft and top cap or am I overly simplifying things?
cheers
Posted : 03/09/2018 9:38 pm
 Neb
Not that simple unfortunately. the equalising (between + and - springs) notch inside the stantion isn't there in the dual position so you can't convert without swapping the uppers. That's expensive and not really worth it.
I switched from a dual position pike to a tf tuned coil conversion which has improved things a little, in hindsight I think I should have sold the forks and bought another set.
Posted : 03/09/2018 9:55 pm
Is that the same on the lyrik then?  Happy to sell and replace if that’s the case.
Posted : 03/09/2018 10:02 pm
 Neb
It's the same across all RS forks with solo/dual air springs
https://rockshox.zendesk.com/hc/en-us/articles/205649528-Can-I-change-my-Solo-Air-fork-to-a-Dual-Position-fork-or-vice-versa-
Posted : 03/09/2018 10:39 pm
Deleted. It wasn't worth it.
Posted : 03/09/2018 11:18 pm
Deleted. It wasn’t worth it
???  What wasn’t worth it?
Posted : 03/09/2018 11:57 pm
Neb
Thanks for the help.  I had dropped TF an email asking same question!  Should’ve known to ask the forum first, my google skills were obviously not wildly off track either as I picked nothing up.  Also saves me dropping the lowers and internals myself.
cheers
Russ
Posted : 04/09/2018 12:00 am
Whoops, just about to try the same with my Dual Position Pikes. Luckily I also have a solo air Pike with decent stanchions (and spotted this thread!) so I guess I'll be using them. The lowers are a bit tatty but I assume the lowers will swap over without any issues.
Posted : 04/09/2018 7:41 pm
