Convert suntour for...
[Closed] Convert suntour fork qloc to 9mm through axle
[#10116247]
I have a 2016 Voodoo Bizango and just bought some new 29er wheels for it,, currently the axle I have for the fork is a 15mm qloc however the WTB wheel and hub I intend to put on needs a 9mm axle for the wheel, can anyone advise of a converter for this or will I need new forks?
Posted : 27/07/2018 10:28 pm
Send the wheels back and get 15mm ones? Or do the wheels convert. No way I'd be going back to 9mm QR these days
Posted : 27/07/2018 10:31 pm
You'd need new lowers on the forks, so better getting a wheel with 15mm hub or as above, maybe there's a conversion available for the hub to make it 15mm.
Posted : 27/07/2018 10:33 pm
You'll end up spending half the cost of a cheap wheel on an adaptor - assuming you can find one, no? Plus all the time wasted mucking about.
70 quid will get you one from Merlin that's plenty good enough for the Bizango. I recently bought one for the rear of mine...
https://www.merlincycles.com/pro-build-chosen-hub-alex-volar-trail-wheels-29-82077.html
Posted : 27/07/2018 10:38 pm
