Convert cable discs...
[Closed] Convert cable discs to hydraulic - Tektro to Avid
[#9703949]
I have a Carrera Subway commuter I'm improving slightly - I believe it has Tektro cable brakes.
I'm looking to convert these to hydraulics, probably Avid Juicy/Elixir as I have the bleeding kit already for my MTB.
Am I going to encounter any problems? Does the caliper bolt on the same lugs, can it use the same disc?
Posted : 05/12/2017 11:16 am
Depends whether your fork has post or tab mounts and whether your brakes are post/tab mounts.
You can get adapters cheaply enough to switch.
The discs will probably be 160mm so should fit but you can use bigger if you want more stopping power - you simply use mount adapters to alllow the calipers to be in the right place.
I'd get a complete set of cheap Shimano Brakes and Discs off eBay. Easy to fit, work well, much cheaper and generally easier to bleed/maintain than most other brakes.
Posted : 05/12/2017 11:25 am
I’ve got some shimano discs you can have for £30. Came off my Voodoo that got written off. Brakes are fine.
Post mount, 180 front 160 rear with adapters.
Posted : 05/12/2017 11:30 am
Wasn't aware of the post/tab difference I'll check. Thanks for the info.
Prawny I've messaged you. I was only thinking Avids due to the bleeding tools I have.
Posted : 05/12/2017 11:54 am
