Compressor advice
[Closed] Compressor advice
[#4526223]
Ayup. Looking for some advice on what the spec should be for a compressor to inflate tubeless tyres e.g. what volume and flow rate would you recommend?
Any brands that are cheap and nasty rather than cheap and cheerful? Budget of somewhere between £100-£150 - but if you can recommend something under that which works then so much the better.
Obviously I should just MTFU and use my lungs to inflate them like the true cycling demi-gods who are the denizens of the forum 😉 , but I figure I'll take this short cut and save myself a few bob (in net present cost terms) on CO2 cartridges, as well as hopefully getting a useful new addition to the toolset for some other jobs that need doing.
Posted : 04/11/2012 9:00 pm
 br
I bought a basic (24l) one from Screwfix a few years ago, it works well.
They've gone up in price though, as mine was £80 including extras.
Edit - take a look on ebay, some like mine for £110.
Posted : 04/11/2012 9:12 pm
Lidl have some at present.
Posted : 04/11/2012 9:15 pm
Mine is a little jcb one. about 25l and 1.5hp. does the job well enough. one charge is enough to seat both tyres, then refill them once the sealant is in.
£89 in lidl if your quick! 3year warranty, mine an aldi one 2years old and going fine
Posted : 04/11/2012 9:17 pm
Thanks, guys - checked Lidl a couple of days ago and saw nowt - will check again! Much obliged 😀
Posted : 04/11/2012 11:02 pm
you have to keep an eye on the website for the special offers.
tbh for around £80-100 you will get a generic 24L compressor that is rebranded by loads of companies. They are pretty much all the same, pretty reliable and will be plenty for tubless.
I like the aldi/lidl stuff as they have good warranties for the same stuff that has 1 year from other places.
Posted : 04/11/2012 11:06 pm
Don't worry to much about attachments/pressure gauges etc IME they work best off the main valve and a direct pipe to the wheel valve (core out). Then its the initial blast of air that does the trick.
Posted : 04/11/2012 11:11 pm
who needs a compressor when you can have [url= http://singletrackworld.com/forum/topic/ghetto-tubeless-inflator-total-cost-9p ]this[/url] for 10 pence.
I use it all the time and it has never failed to seat the tyres.
Posted : 04/11/2012 11:14 pm
 br
[i]Don't worry to much about attachments/pressure gauges etc[/i]
tbh I bought a decent Metebo one as I wanted it to work well with presta valves.
@mashiehood - I was waiting for someone to point out the bodge option. Ta, had been thinking about it, but you underestimate my innate ability to make any bodge go fubar. It's a gift 😀
Posted : 04/11/2012 11:36 pm
Drain, take a gander at the lidl store locator & trawl round any close to you, as the offer was a week or 2ago, one store may still have stock.
Posted : 04/11/2012 11:38 pm
Thanks, z1ppy, nothing showing as available online at the Wells or Wincanton ones but could be a 'phone call will unearth something, here's hoping.
Posted : 05/11/2012 12:09 am
If you need a compressor to inflate tubeless tyres you're doing it wrong...
Posted : 05/11/2012 9:06 am
FW - some people don't want the faff of doing things "the proper" way.
Cannisters and compressors take the pain out of it sometimes :O)
Posted : 05/11/2012 10:42 am
 br
[i]If you need a compressor to inflate tubeless tyres you're doing it wrong...
[/i]
Hmm, if I only wanted to put brand new UST tyres of the correct size (ie width) on UST rims I'd agree with you - otherwise, get a compressor.
Posted : 05/11/2012 11:00 am
I wonder if the lighter fluid + match solution works for bike tyres like it does truck ones? 😈
Posted : 05/11/2012 11:08 am
andyl - no it dosent, i tried everything to mount a Pana XC Pro UST onto a Crossmax. Nothing worked apart from the Ghetto method.
Posted : 05/11/2012 11:48 pm
