Following on from [url= http://www.singletrackworld.com/forum/topic/comparison-dialled-morning-glory-vs-steel-onone-456#post-686596 ]this[/url]...
Anyone ridden both the PA and the 456 enough to be able to describe how the ride compares?
For the purposes of discussion, assume the fork to be a Pike
Just buy either, im sure you will be happy.
*in a morning grump*
I've ridden both and prefer the PA hence thats why i own one. Both good frames and they both do the long(ish) fork thing very well. The PA just edges it for me though as it has a more playful feel to it compared to the 456. If it's any help with frame sizing then i'm 5ft 11" and ride a 17", run it with 70mm stem and it's spot on for both climbing and looning.
EDIT - comments made based on the mkII PA. I understand the mkIII PA has the same geometry but the back end is supposedly a little stiffer and not as comfy to ride, cannot verify this though as not ridden a mkIII.
Really struggled with chainsuck on a 456 made me get rid of it nice ride when it worked though
