Colonsay to Oronsay...
[Closed] Colonsay to Oronsay. road/track?
 ton
[#5378650]
looking at google maps it looks like there is a track across a estuary.
is it passable on a bike?
Posted : 30/07/2013 3:21 pm
Ton - you see the power lines near to top ? that's the crossing 2 weeks ago. At low tides you can walk over :)[img] [/img]
and this is looking the other way, with my kids playing cricket on the beach 🙂
Posted : 30/07/2013 3:35 pm
It's sea which dries to sand from memory, you can certainly walk across. Can't remember if there was a track per se but you will be fine to at least walk over with your bike.
They are only separated a wee bitty bit.
Definitely go though. Colonsay is beautiful.
Posted : 30/07/2013 3:37 pm
another one to whet your appetite, weather isn't like this very often though !
Posted : 30/07/2013 3:41 pm
Ton the crossing is tidal. There is not a track but make sure you follow the vehicle tracks in the sand. You will usually get around 4 hours on Oronsay on a low tide but it very much depends on the tide and the wind. If you cross a bit too early be prepared for a wee paddle at the Oronsay end. I would definitely recommend that you consult a local on Colonsay before you cross. The sand is usually very wet and sticks to everything so make sure you give your bikes a good clean when you get back - it will eat cables! It certainly eats vehicles!
Posted : 30/07/2013 4:48 pm
 ton
thanks for all the info everyone.
Posted : 30/07/2013 6:24 pm
