Call this a PSA if you wish but having just spent the last hour drilling the bolts off so i could change the cleats, could i advise that people check the bolts aren't seized and grease them once in a while.
anyone know if you can buy the metal plate into which the cleats bolts screw, shoes are Sidi Dominators?
yes you can buy them, I think shimano cleats come with said plate
a good slavering of copper slip/grease does the trick. Do up nice and tight and nice and easy to undo months/years later :o).
The plate is standard. Ask your LBS, although they may need to search around to get it as it's not a normal spare part.
BTW, have a look at the recommended torque on your new cleats. You'll be very surprised at how low it is!
Pop in mrmo, ill sort some .
coppaslip. I took some cleat bolts out friday - came straight out.
Always use the appropriate grease / threadlock on bolts - its part of fettling.
I get problems from the Hex heads wearing away.
If you have Eggbeaters and the heads are fubered just snap the little plate that sits under the screws with a screw driver then undo the exposed screws with Molegrips.
I managed to get some out recently that had been in for 10 years! I had thought I was probably going to have to resort to the drill but luckily not. I put anti seize on the new bolts when they went in.
New Shimano cleats now come with the plates you need(the ones we sell do, anyway), but if your shoes are the same as my old Dominators then the fun is only just beginning. Even though the insole is cut you'll have a pig of a job moving it to get to the plate, and getting it to sit back flush afterwards is just as much fun.
