Chris king non boos...
[Closed] Chris king non boost to boost help ??
 snap
[#9644570]
Hi
I keep coming up with blanks here
Is it possible to run a non boost Chris king rear hub on a boost frame
Specifically a Santa Cruz tallboy 3
Thanks in advance
Posted : 03/11/2017 7:30 pm
There are generic axle spacers like from [url= https://www.mtbtools.com/product/adapter-set-rear-hub-boost-application/ ]mtbtools,[/url].
Posted : 03/11/2017 8:13 pm
But if it is a centre lock hub, no.
Posted : 03/11/2017 8:15 pm
 snap
It's Chris king 6bolt
Posted : 03/11/2017 8:19 pm
 snap
Greyspoke
Many thanks for the link
Is there anywhere uk based that supply the spacers
Posted : 03/11/2017 9:07 pm
Not that I’m aware of. A lot of $ for a few small bits of Al isn’t it? You’d think Superstar or BETD etc would get in on it.
Posted : 03/11/2017 9:25 pm
 snap
Has anybody successfully done this with a CK rear hub ..
LBS reckon it can't be done with CK
Posted : 04/11/2017 12:32 pm
D&D cycles used to do a conversion for their GT frames. It comes in around the same price though. I've used mtbtools a few times and he is very reliable.
Posted : 04/11/2017 1:14 pm
Can’t be done. The combination of axle and disc spacing just won’t work. If you space the axle correctly, the rotor won’t be in the right place. Getting both the cassette and rotor in the right place is not possible. And the dishing required to get the rim centred will make the wheel very weak. Sorry......
Posted : 04/11/2017 4:20 pm
Is there not a boostinator equivalent for Chris king hubs?
Posted : 04/11/2017 9:19 pm
Snap, your in the south west right? I had the same issue with a set of bor hubs, got some adaptors made of stainless by a place in Tiverton (Morrish). Real good work.
Posted : 04/11/2017 9:33 pm
@solarider - I have no knowledge of the idiosyncrasies of King hubs, but that is not true in general. Rear boost conversion kits come in two flavours: ones that keep the wheel central (3mm of spacer per side) and come with 6-bolt disc spacers of 3mm, the mtb tools ones are like this; and ones that space the wheel over to the drive-side dropout with 6mm of disc spacer and a 6mm spacer on the non-drive side. The former requires a non-boost chainline, the latter a boost chainline.
@Fat-boy - some kits have replacement hub end caps (like the Wolf Tooth Boostinator, which is of the second type) but they are disc-specific (at least nominally).
Posted : 04/11/2017 9:47 pm
I might have some 5mm and 2.5mm kits left from some frames we made for a company , they eventually switched to our dropout system that runs 142 and 148 with no need for the spacers
Posted : 04/11/2017 10:19 pm
 snap
Neilforrow
Unfortunately I'm in the midlands not the south west I'd be really interested in looking at those can I trouble you to send me some pics
Email in profile
Many thanks
Mickmcd
Again I'd be interested in seeing how you've managed to make it work and possibly purchasing if suitable
Email in profile
Many thanks
Greyspoke
In your opinion which flavour of spacing would work best with my desired combination
CK non boost hub
I'm sorted on the front because I'm getting a frame only tallboy and already have non boost pikes
Posted : 05/11/2017 3:12 pm
Hi Snap sorry to hijack your thead (no forum paging!) - saw a post about a Blur TRc - still have it? I've dropped you a mail in case you do. Ta.
Posted : 05/11/2017 3:40 pm
@snap - I have re-used some non-boost hubs on a new boost frame recently. My decision was dictated by the fact that, at some stage, I intend to buld me some 27.5+ boost-hubbed wheels to run as alternatives, so I went for the spacing-to-the-right option so the wheels will just swap. Well that's the idea.
Another advantage of that option is you have to dish your wheel over to the left, which makes spoke tension more even and in theory leads to a stronger wheel. Which is also the disadvantage, you have to re-dish your wheel, can be a struggle if the nipples are well seized in, I soaked mine in penetrating oil overnight and they turned, albeit noisily.
So if your wheel is fine and you aren't planning swapping with boost-hub wheels, the space-it-in-the middle option would be the one. Either way, you will need disc spacers so your wheel will not just drop back in to a non-boost frame.
Posted : 05/11/2017 6:42 pm
