cheap tapered 15mm ...
[Closed] cheap tapered 15mm rigid fork?
[#6053209]
hi
struggling to find a cheap rigid fork that is tapered and has a 15mm axle
will be replacing a 140mm fork so think im looking for a 29er fork
will just be using the bike for commuting so look for something cheap as possible
best i found so far is http://www.tritoncycles.co.uk/frames-forks-c6/rigid-forks-c51/salsa-cromoto-29er-grande-maxle-rigid-fork-p501?utm_source=google&utm_medium=cpc&utm_term=salsa-cromoto-29er-grande-maxle-rigid-fork-sizes-taper-sizes-taper-fksac9mtk&utm_campaign=product%2Blisting%2Bads#3984
Posted : 20/03/2014 10:06 pm
If only for commuting why not consider an [url= http://www.chainreactioncycles.com/nukeproof-conversion-kit-15mm-to-qr/rp-prod80192 ]adapter[/url] for your front wheel? It'd mean far, [i]far[/i] more fork options.
Posted : 20/03/2014 10:13 pm
http://www.alibaba.com/product-detail/2014-newest-full-carbon-mtb-fork_1538866825.html
I've bought one. £110 with an axle and delivery.
It's in customs at the moment. Probably £35 for that.
So, around £150 all in.
Posted : 20/03/2014 10:20 pm
the adapter might be the cheapest option
ska-49 i seen them but it looks as if you need a nut on the end of the axle instead of the fork being threaded so will require a spanner to remove wheel?
Posted : 20/03/2014 10:41 pm
I'm not sure. Will report back when they arrive if you're interested.
Posted : 20/03/2014 10:49 pm
please do
Posted : 20/03/2014 11:22 pm
Forks arrived today. Very pleased. They are incredibly stiff and light. No flex with gentle squeezing.
Postage time was brilliant from the producer but Parcel Force/HM Revenue are a joke. It took 4 days to hit our shores and then 12 days to reach me!
HM Revenues and customs took a lovely £23.65 on a product market at little over the same value.
The axle is brilliant. Was a nice surprise. I was expecting a solid axle with a nut, but no! It's a direct copy of the shimano through axle.
The proportions of the fork are crazy. The legs are huge and the crown dwarfs the tapered steerer. Yes, thats tapered! Very light. Kitchen scales indicate 700g. Once the axle is in the fork has absolutely no flex at all. The steerer is plenty long but doesn't come with a carbon bung. Face brake mounts which are nicely built up too.
Photos once they've been installed and a mini review once ridden.
Big thanks to Hellen at XMIPlay!
Posted : 27/03/2014 8:58 pm
thanks for the write up/pictures
just one thing im still not 100% sure on how the axle works? as usually on a suspension fork one side of the dropout is threaded to accept the axle but this looks different?
Posted : 29/03/2014 8:51 pm
Looks like a bolt on the other side. Bit like a 9mm QR. Looks lovely.
Posted : 29/03/2014 10:28 pm
Same as the kenesis one - it's a threaded nut with with a knurled finish similar to a seat clamp. I actually prefer it to a threaded fork leg because if it gets buttered, you replace the nut, not 're-tap' the forks
Posted : 29/03/2014 10:41 pm
As Flange says- it's a threaded nut.
It's for sale now if you're interested!
Posted : 30/03/2014 7:26 pm
May have been interested if they were straight 1 1/8. My frame is old school unfortunately 🙁
Posted : 30/03/2014 7:56 pm
I've had one of those forks from XMI Play since Christmas now and it's been fine
Posted : 30/03/2014 8:53 pm
 dobo
I'm draging up this thread again as thinking of some new forks, the salsa cromoto grande maxle have my eye but the chinese carbon is tempting.
ska-49 why did you sell yours?
RAGGATIP how has your fork been, still got it?
anyone else want to chip in about these 15mm rigid maxle forks?
Posted : 13/10/2014 9:42 pm
