Cheap bike moan
[Closed] Cheap bike moan
 Taff
[#1106746]
My brother in law bought a Giant bike a while back for a couple of hundred quid and he had 28-42 tooth chain rings up front and he wanted to put some bigger rings on it. Because they were fixed I bought some new FSA cranks from CRC, square taper. Now I've gone to put them on and no matter how tight I tighten the cranks they won't sit far enough back on the taper. Im' going to try and find some old botom brackets for a comparison but I'm pretty sure that square tapers are one size only. Has any one come across this before.
Posted : 06/12/2009 10:11 pm
Usually different axle lengths for different chainsets on square taper.
Posted : 06/12/2009 10:37 pm
 Taff
But the size if the taper shouldn't vary though should it. The other option is to get a shorter b/b as it was quite long anyway but trying to work out what's wrong with the current one
Posted : 06/12/2009 10:41 pm
Yes!!!!!
Just had EXATCTLY this problem!!
Refit the original cranks fully, and measure the distance the outer ring is from a fixed point on the frame with an accurate method. I used a steel rule
Fit the new cranks again and measure the same thing.
Double the difference (remember it's a bit both sides) and order a BB that is that much shorter in the axle, or a bit less
A cheap BB is only about £8 on CRC and you don't have an option really....,
Posted : 06/12/2009 10:48 pm
I had a similar problem with a Saracen years ago. Right from day one I could not get it to drop into the granny ring properly. It was a right faf. Swapped the chain set over to Deore and it shifted perfectly. There was a big difference between the two chain sets.
Posted : 06/12/2009 10:54 pm
It's true. Chainsets have different chainlines. Well cheap SqT ones do anyway!
My bike came with a Suntour crank. To get the FSA one I bought to fit with the rings in the same place I had to go from a 122mm axle to a 113mm. That's 4.5mm difference a side. And that's enough to make the front mech unable to shift to the big ring
Posted : 06/12/2009 11:03 pm
Cheapo chainset was likely running on a 122 or even 125mm bb. Your FSA is probably gonna want a 113mm. Square taper bbs vary,roughly from 103mm to 130mm - needs to be right.
Posted : 06/12/2009 11:23 pm
There are two standards of taper - JIS and ISO. make sure you have the right taper for the bb/cranks.
Posted : 06/12/2009 11:25 pm
 Taff
hmmmf, I knew the bb length would come into play. These cranks were suntours and gone to FSA. Will have a measure tomorrow and get a new b/b. The drivetrain is going to be better than the bike itself!
Posted : 06/12/2009 11:29 pm
