Air
Currently had a stroke of 62.5mm
Need 65mm
Assume it's just a case of remove 2.5mm spacer "mechanically" i.e. cut it off the shaft as opposed to dismantle.
2022 btw
Posted : 27/07/2024 8:58 pm
Sort of, the 2023 ones have a hydraulic bottom out setup internally, it will still think the 62.5 is the bottom, so theres more to it
Posted : 27/07/2024 10:41 pm
It's not a 2023 buddy (last line of the op)
Posted : 28/07/2024 8:15 am
Sorted. Open Aircan, find grey spacer, clip off with side cutters, pop air can back on. Done
Posted : 28/07/2024 5:56 pm
