changing travel on ...
[Closed] changing travel on a revelation
[#2254550]
hi i have a 2010 150mm team revalation fork, it came with spacers to knock down to 130/140mm , how much would a bike shop charge to do this, or alternatively could it easily be done myself?
thank you
Posted : 05/12/2010 11:10 am
its very easy, and its good to learn as well since changing the oil in the lowers is required maintenance and follows the same procedure. You'll need a socket set, allen key and circlip pliers.
http://www.bikeradar.com/gear/article/workshop-rockshox-revelation-lower-leg-service-24649
Posted : 05/12/2010 11:27 am
