Changing Hope IS to...
[Closed] Changing Hope IS to P/Mount
[#1657617]
I've carried out the conversion, but it means fitting a larger disc. 160 to 180mm.
Anyone know of a conversion that will allow the use of the 160mm disc?
Not the end of the world if it can't be done, but it's the aesthetics and extra weight I don't like.
Posted : 30/05/2010 6:31 pm
You'll need the iso to post mount bracket 160mm and can buy them for £5 in sure. I just helped my mate do this a few months ago with his steed:)
Posted : 30/05/2010 6:39 pm
I've seen a KCNC IS 160mm to PM 160mm advertised, but wasn't sure if it was right. Why would Hope supply an adapter that meant a 20mm size increase?
Posted : 30/05/2010 6:44 pm
try here:
http://www.a2zcomponents.com
someone recommended them to me but it didn't work, (i've still got it in the garage if you wanna try) martindddde AT googlemail.com
Posted : 30/05/2010 6:48 pm
its a mine field, mebbe this???
http://www.chainreactioncycles.com/Models.aspx?ModelID=50099
http://www.chainreactioncycles.com/Models.aspx?ModelID=42795
i'll quite happily pop mine in the post to you
Posted : 30/05/2010 6:53 pm
qwerty YGM.
Ta
Posted : 30/05/2010 7:01 pm
