chainset tightening...
[Closed] chainset tightening plastic nut wont take?
[#4509997]
ive noticed by non-drive side crank had some play in it, i loosened the clamping bolts and tried to tighten it via the plastic nut and its will barely tighten without popping out the thread.....
- Is it knackered?
- Can i buy a replacement plastic but only?
Posted : 30/10/2012 3:06 pm
How much are you trying to tighten it? There is a torque on there which is VERY low for a reason. It is only a bearing pre-load.
And yes you can buy them for about £2-3.
Posted : 30/10/2012 3:13 pm
Is it broken? Very easy to overtighten and break those plastic bolts. You can buy metal ones, but they make it even easier to put too much preload in the bearings!
Posted : 30/10/2012 3:16 pm
is the plastic bit only just connecting with the threads. Or is it tightening all the way and poping off.
Either way you might have a issue with spacing. if your chain line is good leave the drive side and adjust the non drive side.
