Chain wear help
[Closed] Chain wear help
[#317568]
Using my park chain wear measuring tool i put the curved end into a link and the other end into a space with some force (the .75 side btw)
Does this mean my cassette will accept a new chain still?
Posted : 18/02/2009 6:32 pm
Hard to tell, I've had no end of troubles trying to determine if cassettes were worn, and if chains were stretched. Measuring a brand spanking new chain showed it to be 0.25 out to begin with on mine :S
Posted : 18/02/2009 6:52 pm
you're supposed to use the guage to measure the bits you've worn off not the bits that are left! 😆
Posted : 18/02/2009 6:53 pm
Not sure about your definitions of 'link' and 'space', but if you've used it properly you've got a bit of life left, once it goes in easy, but before the 1.0 side does, change the chain and the cassette will be fine.
Posted : 18/02/2009 8:58 pm
space as in "no metal"
Link as in joining pin and roller
Posted : 18/02/2009 9:00 pm
