chain falling off o...
[Closed] chain falling off on shimano slx drivetrain
[#11890093]
hi there on my one one scandal the chain keeps falling off when I pedal over roots or bumps in my top gear there also seems to be more chain slap then there should be with the shadow+. the chain is not worn though. any ideas why this is happening
Posted : 19/05/2021 9:41 pm
Falling off the front? Or coming off the smallest sprocket at the rear?
Posted : 19/05/2021 9:56 pm
falling off the front
Posted : 19/05/2021 10:00 pm
Is it a clutch mech?
The clutch could be loose (they can be tightened) or turned off?
Posted : 19/05/2021 10:08 pm
as above , clutch not working
As above, is the clutch on?
Is the front ring narrow wide?
Is the front ring worn out?
ok I will try that thanks
Posted : 19/05/2021 10:11 pm
Sometimes the clutch will benefit from a service as well.
Posted : 19/05/2021 10:22 pm
Clutch on? Clutch adjustment correct? Clutch in good working condition? Chainring worn? Chain length correct?
Personally I still run a guide on 1x narrow wide
Posted : 20/05/2021 12:34 am
Me too, because they're not perfect.
Posted : 20/05/2021 4:27 pm
I dont have iscg05 mounts
Posted : 20/05/2021 5:34 pm
You can get BB mount chain guides, and seat tube mounted ones too.
Posted : 20/05/2021 7:57 pm
ok thanks, any recommendations?
Posted : 20/05/2021 9:45 pm
Having never fitted a chainguide to a hardtail with a NW and clutch mech and smashed my way round the alps, peaks etc etc, I would say that there is defo something else going on there.
Is the NW ring worn?  They defo get less grippy.
How old is the mech?  Have you serviced the clutch?
How long is the chain? Pics are helpful.  Show the gears with the chain in the biggest cog on the back.
Posted : 21/05/2021 11:15 am
tightening the clutch did not seem to do much
here is a photo
here is a photo
Posted : 21/05/2021 7:52 pm
I had a chain which constantly dropped, turned out to be a worn quick link which was the issue
Posted : 23/05/2021 11:48 am
