I know that you can mount 6 bolt rotors on centrelock hubs but is there anyway that you can do this the other way around... the google machine doesn't have much out there from what I can see.
Cheers.
Posted : 01/07/2011 4:39 pm
Might be easier just to swap the centerlock rotors for 6-bolt? Usually better to keep things simple!
I have a pair of brand new Avid 160mm 6-bolt rotors and I need a pair of similar centrelock rotors... Could swap if it helps.
Posted : 02/07/2011 9:02 am
I'm afraid not - the spacing correct isn't possible
Rob
[url= http://www.bigrobracing.co.uk ]bigrobracing.co.uk[/url]
Posted : 02/07/2011 9:28 am
I should clarify, an adaptor could be made, but the disc would not line up with the calliper, it would be too far outboard
Posted : 02/07/2011 9:29 am
