Cassette lockring p...
[Closed] Cassette lockring pain - there must be another way!?!
[#5277190]
You know when you grip the cassette with a chain whip and then apply force to spanner on the lockring socket until it cracks and slips - well I always seem to ham fistidly stuff my fingers into the spokes, which is quite painful and last nights atempt has given me a black fingernail!
There must be another less painful way?
Posted : 25/06/2013 9:59 am
use a longer lever - I use a 2ft bar on my lockring tool.
It;
1) leaves my hand further away from the spokes as it's nearer the rim.
2) means I need to use less force so don't end up mashing my hand into stuff when the lock ring 'gives'.
Posted : 25/06/2013 10:01 am
use a 1/2" drive longer breaker bar..
put a glove on?
stand with wheel in front of you and push down on both chain whip and cassette tool
Posted : 25/06/2013 10:02 am
Wheel off, between legs, chain whip on, lockring tool on, QR skewer on, spanner on.
No need to get your fingers mushed in the spokes
+1 for above.
I use long wrench and gloves. Hardly need any force at all.
Posted : 25/06/2013 10:03 am
Pedros cassette clamp
Don't do it up so tight in the first place?
Posted : 25/06/2013 10:05 am
Vice
Gloves, long wrench. I often use a breaker bar on stuff like cranks and sometimes the lockring. Dead easy then and at least one hand isn't going to smash into the cassette.
Posted : 25/06/2013 10:20 am
Excellent thanks! Bye bye mashed fingers! :mrgreen:
I'll go for the breaker bar and glove suggestion.
PS My mashed little pinkie hurts as I type this 😳
Posted : 25/06/2013 10:21 am
+ some copper slip.
how fat are your hands if they hit the spokes when your removing the lock ring ?
Posted : 25/06/2013 10:22 am
Lockring tool in the vice as above 🙄
Standing with wheel resting against legs and cassette away from you does seem to help in terms of getting enough leverage and keeping hands away from danger zones when it does release.
Posted : 25/06/2013 10:24 am
trail_rat
Ape like shovels with fingers like good butchers sausages :mrgreen:
Also liking the vice option, but my vice is not ideally positioned for wheel work..
Posted : 25/06/2013 10:26 am
But in a vice, you've still got to stop the freewheel from spinning, so surely more of a faff than just between the legs?
Posted : 25/06/2013 10:28 am
Put the wheel at 90 degrees to a wall so the tyre is up against, stand with the wheel loosely between your legs (just to keep it level). Use the whip to push / rotate the wheel against the wall whilst undoing the locknut.
Trying to undo the locknut with the cassette facing you will end in pain.
Posted : 25/06/2013 10:29 am
Depends how tight it is,but having the lockring tool solid in a vice has always made it feel less of a faff to me ,and you also get to use the rim as a lever while the whip is held in place.
Posted : 25/06/2013 10:34 am
you should set the whip handle and spanner handle 5degrees apart from each other.
Then with both hands clasped around both handles at the same time towards their ends, squeeze the handles together.
With no arm muscle tension there's virtually no risk of slamming your hand into anything when the tension gives.
Same technique can be applied to pedals using an allen key and the crank arm and to crank arm pullers using the spanner and crank arm.
Posted : 25/06/2013 10:37 am
Pair of "riggers" gloves from a builders merchant or BandQ. Saves a lot of pain in you slip.
Posted : 25/06/2013 10:40 am
If your fingernail has gone black, you may have a pressurised pool of blood behind it. A top tip I learnt after squishing my finger in a door and making the nail go black was to heat up a straightened paper clip in a flame (gas hob is perfect) until it goes red hot, then push it v.v. gently through the nail. The hot metal melts a small hole through the nail and the blood underneath quenches it before you burn the nail bed. Then when the paper clip comes out the pressure is released and the (majority of) the pain goes. I found out it quite scary when I did it, but the relief was immense!
Posted : 25/06/2013 11:08 am
I've had one of [url= http://www.woollypigs.com/2011/10/meet-the-hypercracker/ ]these[/url] for about 20 years, works a treat, although often I just grab hold of the cassette with a rag and use it by hand, assuming the cassette isn't mega tight.
Cheers, Rich
Posted : 25/06/2013 11:13 am
Hyper cracker has served me well for many many years, but they are a bit of a faff to fit. Plus I dont think they've been available for a long time now. Mine lives in the camelback for emergency use only these days.
Posted : 25/06/2013 11:30 am
another vote for stop doing it so tightly in the first place.
Posted : 25/06/2013 11:35 am
Stoner+1 - I just set handles close together and squeeze.
Posted : 25/06/2013 11:37 am
All good stuff, although I do wonder how I manage to make it through the day with waht appears to be the brain power of Winnie the Pooh :mrgreen:
Posted : 25/06/2013 12:05 pm
Don't overtighten it in the first place? In theory it should tighten under load as it turns in the same direction as the thread.
I always just nip them up, never needed anything more than a 12" wrench to loosen
Posted : 25/06/2013 12:14 pm
Cheapo leather gardening gloves. Good for tasks when a slip will mean contact with something pointy.
Also set yourself up so the lockring tool and the chain whip are fairly close together (12 and 2 not 12 and 6) so when it gives there is less movement.
Posted : 25/06/2013 12:21 pm
