I've offered to take dinner to a pals and have a cottage pie thawing. They are 9 miles away and I'd prefer to ride if possible.
I can't see a way of securely transporting it with rack or panniers, any ideas?
Pie is say 12" x 9".
Nicely wrapped up, then attached with bungee cords to the rack? Otherwise, suspended in a makeshift cradle from the top tube - although this may require a bow-legged riding position which may not be possible to maintain for 9 miles. There may also be a risk of pie fouling to the front in the event of steep gradients.
Get a taxi for the pie 🙂
Seriously!? Can you not work this one out for yourself!?
Post pie ( recorded delivery).. That way it gets tracked and you know exactly when it will arrive.
Then cycle over
Simples.
Eat it,
Vomit it back up.
Problem solved.
Enjoy and don't thank me. 😆
Eat the pie before you go, then simply tell everyone how delicious it was when you get there.
EDIT: Bah! Too slow.
OK a serious suggestion: deconstruct the pie, carry the filling and mash in separate sealed pots then remake when you get there.
Contact these people (I suspect binners is the mastermind behind the outfit) and ask them how they do it.
Carry it in a reputedly self sealing tupperware container
I carried a 1.5k Apple and berry crumble back from work ,with a couple of servings of creme Anglaise last night, it was balanced on the bars supported by my hand. There are no hills and i only live 1k away but my wrist felt the burn .Starting to move and dismounting was a wobbly affair but today we eat crumble!
Seems expensive.
Broom handle taped to top tube so that it protrudes out the front of the bike past the front wheel.
Drill three holes in the rim of a circular tray at equal points around the circumference. Tie three lengths of string to tray through holes.
Tie tray to end of broom handle so that pie can sit on tray and be kept level no matter how much you rad the gnarl on the way to your friends.
[img] https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcR-n_8-r-FNhPj6uidKqLv9mpdW9H7x_h6nigAmejjewVfun0Zc2A [/img]
Go on, do it, you know you want to! Carbon fibre fork mounted pie carrier, and matching brake mount on the other leg, awsome.
Can't help sorry. But best thread title for a long while.
Hmmm. If only I had a basket I could zip tie to my rack.
💡 Ooh! I actually have a wicker basket!
coatesy - if only I had the time, I need to get there by 4:30 or so.
Its the new MacBookSeems expensive.
Or this [url= http://www.commutebybike.com/2011/06/07/the-hybridbackpack-pizza-test/ ]technology![/url]
Put it back in the freezer to reharden, carry as a frozen lump, defrost using friends macrowave and heat in their oven.
*not sure cottage pie is a proper [i]pie[/i]
A real proper thread a man can respect, excellent. None of your I don't want to accidentally glance at your cock while waiting for my bread machine to break nonsense.
My usual trick if the pie is below the lid of the container is to put a breadboard over the top and then tie the whole thing together with a strap. Then a folder towel on the rack (for a small bit of bump insulation), pie and board on top, then another strap to tie it to the rack. This stap also usually goes through the saddle to ensure it stays up.
If the pie is higher than the edge of the container then it is allowed to eat as much as is necessary to get it below the said height.
Wrong kind of pie, cottage pie is not a real pie. Next time get a real Fray Bentos pie which comes in its own tin. You could probably kick it the whole way there and it would still taste just as good.
Do you not have a personal pie caddy following you with a selection of savoury and sweet pies, allowing you to select the correct pie for each section of he ride?
Phone up tell them you can't make it. Eat humble pie.
leffeboy may have it. If it rains though I am driving 😡
I'd advise caution - I once ended up in hospital at 2am after trying to carry a kebab by bike. Of course, I was also transporting several beers at the time too 😀
I can't solve cynic-al's problem, but I'm starting to seriously think about baking pasties the same size and shape as a water bottle.
Yumm!
A bit like how you can't use a (single-wheel) wheelbarrow one-handed.
Not this man,he posted up before 6.00 am with this dilemma. 🙄
This means that he was fretting about it all night ,what a let down ,from the one time spoon bending (almost hingeneer) god.
[i]..is disappointed[/i] 🙂
My uni mates tied Fray Bentos pie tins to my car bumper when I got married. Cheeky bleeders.
I misread Stoners one handed tray advert first time round, thought it's said keep a free hand to grab for a crotch. 🙂
Is it a hairy pie?
How'd it go?
Yes how did it go, need to know! What tyres did you use on the pie transportation bike?
Come on - the suspense is killing me...
Brilliant post - cheered my up massively after a miserable 18 hours 🙂
