Carbon saddle/seatp...
[Closed] Carbon saddle/seatpost woes
[#6877322]
Bought a cheapo carbon saddle from the bay just for teh lolz & to have as much carbon componentry as poss. on my XC bike - have just "discovered" oval rails :/
What to do? I assume all carbon saddles have these kinda rails? So, should I be looking for a seatpost to match or might converters be available? I also got a nice second hand (cheapish) Next SL seatpost for it to go on, but it doesn't...
Posted : 20/02/2015 2:54 pm
I can't help but I'm interested to know what the problem is. I thought the rails were ovalised for strength but still fitted a normal clamp so long as it clamps the top and bottom of the rails rather than the sides?
Posted : 20/02/2015 7:10 pm
 Haze
What Rubber says sounds about right, at least I hope so as I have a nice new Fizik on order...
Posted : 20/02/2015 7:15 pm
Not all seat post clamps will take the larger rails - some need a different clamp; Bontrager spring to mind.
can't think why a Next SL wouldn't work though...
Posted : 20/02/2015 7:19 pm
@rob Hilton
Many carbon saddles use ovalised rails for strength, but you end up with a larger clamping cross section, typically 7 x 9 mm, whereas round section cromo rails typically are 7 x 7 mm
As long as your seat post can accommodate the larger section it will work, try the seat post manufacture's website should list the info.
Posted : 20/02/2015 9:38 pm
My S-Works seatpost came with 2 top clamps:
1 for Alloy rails & 1 for 7 x 9mm carbon rails.
Posted : 20/02/2015 9:47 pm
With a newer one it wouldn't be an issue, as they clamp top & bottom, but the older ones have side clamps - kind of a square peg in round hole situation.
Yep, this is the issue. I can clearly see the shape of the rails won't mate with the clamps, so I'll have to get rid of the seatpost and scour the classifieds/ebay for a suitable replacement...
Posted : 22/02/2015 10:28 am
