cannondale reducer ...
[Closed] cannondale reducer cups question
[#352958]
can i just slot some reducer cups in and use standard forks or is it a full headset job ? ive heard there are cups but i cant find them . cheers
Posted : 01/03/2009 10:41 pm
Cups just slot in. I've used them before and have a set in the shed if you're interested, £15 posted?
I currently use a reducing headset, an FSA Orbit Z1.5 R, good piece of kit but around 350 if you can find one.
Rich
Posted : 01/03/2009 10:45 pm
ygm
Posted : 01/03/2009 10:46 pm
no you havent lol can you mail me 😉
Posted : 01/03/2009 10:47 pm
 IA
You can get cups. There are some in mine.
Or use a reducer headset, there are loads about. Just make sure that a) they're not too deep insertion, and b) you have knob clearance on the downtube for your forks.
Posted : 01/03/2009 10:49 pm
btw what forks are you running ? this is to replace fatty ultra dlr80 ones i measure the a to c at 485mm so im thinking reba 115mm is pretty much spot on in a swap that or a 120mm fox is there are any
Posted : 01/03/2009 10:53 pm
Bulb-End; the Orbit Z1.5R is what I've used too, and won't alter the height of things at all, but you could also run a [url= http://www.windwave.co.uk/windwave/101-1250.html ]normal reducer headset[/url], but this would increase the stack height/amount of steerer tube needed.
Running the Z1.5R with a 100mm fork was fine. But as mentioned; watch out that the knobs/caps on your forks will clear the downtube. A Reba 115/120 will be fine.
BTW, I think the above poster meant £50, not £350!!!
Posted : 01/03/2009 11:02 pm
cooli cheers freddie boy 😉
Posted : 01/03/2009 11:11 pm
Good, so you're keeping the Dale frame then?
Might you be selling the forks, in that case? They could pop on a friend's bike, actually.
Posted : 01/03/2009 11:16 pm
im still waiting on a guy getting back to me about a frame forks swap but if it goes pete tong i may well be selling the forks but what are they worth ? about 18 months old and unmarked fatty ultra dlr80 (rebound and lockout)
Posted : 01/03/2009 11:20 pm
Gawd knows, more than a slap, I'd say?
Posted : 01/03/2009 11:21 pm
aye mate prob right lol id also have my new 90mm hope 1.5 stem too
Posted : 01/03/2009 11:22 pm
he can buy a set at chevin cycles in otley for only £700 lol how mads that
Posted : 01/03/2009 11:28 pm
Sorry to butt in but Rudeboy, I am building up a taurine at the mo' and was hoping to use a set of Magura Odur 100mm forks - is this reducer headset what I need to fit them?
Posted : 01/03/2009 11:29 pm
Yes, either of the FSA ones will be fine.
Basically, it replaces the large diameter bearing, and cups, of the Headshock system. You get alu cups which press into the frame, and smaller diameter bearings to take a 1 1/8 fork. Be very careful when removing/fitting the cups, to avoid damaging the frame, of course. Possibly worth going to a Cannondale dealer, who know about such things, to swap the headsets over.
Of course, the Lefty is the proper fork to use, on a Dale frame!
Firebulb; Cannondale forks are silly money, on their own! Mental!
Posted : 01/03/2009 11:37 pm
i know id love a lefty 110 on it but new wheels would be needed then bugger lol that and they cost a fortune
Posted : 01/03/2009 11:39 pm
Johnny63 - reducer headsets like the Orbit Z1.5R won't fit cannondale carbon SI headtubes. You will have to get an adapter from a cannondale dealer.(this is the case with rush frames - I assume taurines are the same)
Posted : 01/03/2009 11:41 pm
Tell me about it. I bought a Lefty off here over a year ago. Turned down a nice set of wheels for an extra £100. Then had to buy a Lefty Hub for £70,and swapped the rim over. For the extra £30, I cooduv saved meself the hassle. And had a nice Hope hubbed rear wheel spare too! FAIL.
Posted : 01/03/2009 11:42 pm
fail indeed lol
Posted : 01/03/2009 11:50 pm
thanks nostoc
Posted : 02/03/2009 12:05 am
Ooh, I din't know the info that nostoc posted.
Are the Rush and taurine frames a different HT diameter? Strange...
Those FSA adapter headsets are designed to be used with Dale frames, and mine certainly went in ok.
Posted : 02/03/2009 12:08 am
what have you got rudeboy
Posted : 02/03/2009 12:10 am
It's about a 2000 CAAD 4. Si headset bearings.
Posted : 02/03/2009 1:54 am
nice 😉 can you bob me a mail re my headshock mate . cheers
Posted : 02/03/2009 5:42 pm
