Can you run an 11 s...
[Closed] Can you run an 11 speed 32t cassette with a standard 6700 rear mech?
[#9348620]
Hi guys,
got a mate of a mate whos just dropped out of the peak epic, I'm overweight for a hilly course and have agreed to step in.
I've currently got a 28 fitted on my 6700 drivetrain.
Will a 32t run ok?
If not, what mech do I need too?
Posted : 26/05/2017 9:12 am
Maybe, it depends on the length of the rear mech hanger
I've had success on trek madones and domanes, also on a cervelo r3.
Didn't work on a Specialized Tramac sl3
If it doesn't work, you did to change to a long cage gs rear mech
Posted : 26/05/2017 9:30 am
A 30T definitely works (have a 12-30t tiagra cassette with 6700 mech on my tourer).
Posted : 26/05/2017 9:32 am
You could get a 10 speed med cage 105 mech for £30 if your current short cage mech won't do
Posted : 26/05/2017 9:46 am
A mate has a 32 on a short cage Ultegra 11 speed mech. Had to wind the B screw in a bit and we felt that using the 30 and 32 with the outer was pushing things a bit but it works perfectly
Posted : 26/05/2017 9:50 am
And you'll probably need a longer chain. Mine was nearly new and I had kept the spare links so just added it in with an extra split link. Seems to be fine.
Posted : 26/05/2017 9:56 am
Thanks guys, its a trek emonda so maybe might work based on the madone and domane experience above?
I'll give it a whirl with just a cassette and then go from there.
Thanks for the input everyone. Long ride tomorrow now then rest for a week!
Posted : 26/05/2017 10:19 am
Make sure you check it in big/ big. I know you'll try to avoid cross chaining but you don't want to jam the mech on the road because the chain is too short.
Posted : 26/05/2017 10:23 am
Yeh I will do, I'll try it in big big under load too.
Posted : 26/05/2017 10:24 am
Sorry misread your post, 6700 ultegra is 10 speed, why are you putting an 11 speed cassette on?
Posted : 26/05/2017 10:27 am
Maybe its not 6700, it's 11 speed 105 I've got on there. My bad
Posted : 26/05/2017 10:32 am
5800 then, that's ok. I went for an 11-32 on my gravel bike and had to go for a bigger mech.
Posted : 26/05/2017 10:38 am
That's 5800. Supposedly the short cage only goes up to 28T, but you might be lucky and have the medium cage fitted.
Posted : 26/05/2017 10:39 am
How can I tell? If it is medium cage then will it work?
Posted : 26/05/2017 10:53 am
It's stock one of these
https://www.rutlandcycling.com/281204/products/trek-emonda-sl5-2015-mens-carbon-road-bike.aspx
Posted : 26/05/2017 10:54 am
Medium cage will work and is "gs". Short cage will probably not work and is "ss". It's probably stamped on the back of the derailleur. The picture in your link looks like a short cage to me though I can't be 100% sure.
Posted : 26/05/2017 11:14 am
Just looked at my 5800 with a 11-32. It's in the back of the car right now so can't see markings properly but if it helps distance between jockey wheels is approx 90mm. That photo looks shorter so maybe it won't do the job.
Posted : 26/05/2017 11:19 am
Cheers avDave2, that's a help... I'll get the ruler out.
Posted : 26/05/2017 11:36 am
