Can you fit a BB mo...
[Closed] Can you fit a BB mounted chain guide to an isis style BB?
 ianv
[#3370116]
Or is it just the newer external bearing types?
Posted : 20/11/2011 10:48 am
If its a 68mm bb shell just use a 73mm one with the guide as the spacer.I think you can get ones for E-type front mechs which will work with a guide instead.
Posted : 20/11/2011 10:57 am
I'm using a bb mounted E13 drs with an isis bb so I would say yes. I had to still use the driveside BB spacer though otherwise the granny ring bolts scuff the plate of the guide. Might change the chain line a bit, doesn't really seem to make any difference though.
Posted : 20/11/2011 11:03 am
