THat is all
Why would you want to?
Most likely not sure if spares or aftermarket are available yet though
both appear to he the same damper layout.. so I'd assume yes.
Because my current fork is open bath RL.
Yes, Mojo will do it with a service http://www.mojo.co.uk/fitupgrade.html
If you're feeling very flush they'll even swap out the stanchions for Kashima as well.
HTH
SM
You mean I could send my 9mm, open bath ,non kashima forks upgraded to 15mm, ctd fit cartridge, kashima forks?Woohoo....where do I sign 😉
@Rorschach, send me your forks and £800 and i will do that for u sir, they will be as good as new.
Thats a FIT upgrade not CTDsmartmonkey - MemberYes, Mojo will do it with a service http://www.mojo.co.uk/fitupgrade.html
If you're feeling very flush they'll even swap out the stanchions for Kashima as well.HTH
SM
This. I was well aware that FIT upgrades are available.
Funnily enough, I am sure that buying all of the parts for a 32 RLC fork is cheaper than buying the fork was. Below (except for bushings) are Mojo parts prices, likely you can get a touch cheaper from some of the independent tuners:
Lowers: 170
Kashima CSU: 166
FIT Damper: 151
Float spring: 75
Bushings: 45 (this is loco tuning price)
£600ish for all that lot.
Just email mojo and ask, they probably would since it's just an internals swap with a different external control. Unlikely to be cheap, but I'm sure you know that already.
