Camelbak cleaning
[Closed] Camelbak cleaning
[#1875857]
I noticed at the weekend my camelbak tube has some nasty black stuff in it 😯 any recommendations on cleaning?
Do I stump up the £16-20 for the genuine cleaning kit or is there a cheaper/better alternative.
Posted : 09/08/2010 12:40 pm
Miltons Sterilising Tablets, put them in there for 24 hours, flush through, may need another 24 hours. Saves £20 for a new bladder!
Posted : 09/08/2010 12:42 pm
Only use water in it, after use just empty it and lob it in the freezer, then do the Milton thing once in a while.
Posted : 09/08/2010 12:45 pm
Try also Bicarbonate of Soda.
Posted : 09/08/2010 12:46 pm
You need one of the tube / 'gun barrel' cleaning brushes to get the gunk out, sterilising fluid will not clean it on it own.
Also, store your bladder and tube in the freezer between rides, it stops the germs growing.
Posted : 09/08/2010 12:47 pm
If money no object get a cleaning kit and soak in mild milton 🙂
£10
Posted : 09/08/2010 12:48 pm
Milton tablets will sterilise it ok but i don't think they'll actually shift the black stuff. First time i used the proper brush down the tube was pretty revealing. 😯
Better than Milton, try Denture cleaning tabs.. nice fresh taste, not bleach !
Then store in the freezer when not in use..
+1 for Freezer
Use all sorts in mine but always freeze it, never had any nasty stuff in years.
Posted : 09/08/2010 12:49 pm
 j_me
I blast mine with steam from the espresso machine every now and then.
freezing it makes them prone to cracking however, i've had that when filling it before a ride and leaking all over the place. its just as easy to use tablets and get the brush, its not like the brush wears out!
Posted : 09/08/2010 12:50 pm
yep do the milton cleaning once in a while... after 'every' ride mine goes into the freezer.... stays clean all the time then !!! you dont want that nasty black stuff in it at all..... soddin Gremlins they are out to get you- Blast them away ! 😉
Posted : 09/08/2010 12:51 pm
decathlon do cheap cleaing kit with all the brushes etc... bout £11 i think
Posted : 09/08/2010 12:52 pm
Denture tablets + store in fridge
Posted : 09/08/2010 12:59 pm
The easiest way to keep it clean is to wash it as soon as you get home. I use nothing more complicated than a good rinse out with hot water and then store it full of water with a drop or two of antibacterial washing up liquid.
I made a thin wire tool to pull lumps of cotton wool through the pipe - much cheaper than Camelbak's tool.
Posted : 09/08/2010 1:00 pm
If you have one, a coffee machine - blast steam through the hose.
Posted : 09/08/2010 1:01 pm
really !!! a coffee machine blast.... id like to see a 10 second video on that..lol.... its something mr Bean wud do...lol 😉
Posted : 09/08/2010 1:03 pm
I've bought a web-tex cleaning kit from Ebay £10 delivered. Will report back to how good it is.
Cheers for all the suggestions, also going to try the denture cleaning tablets.
Posted : 09/08/2010 1:16 pm
