Calling 301 owners:...
[Closed] Calling 301 owners: Liteville bearings!
[#7148131]
So, I've just bought a Liteville 301, second hand. Swapping out the mounted 160mm rocker arms for 140mm ones, the needle bearings in one side of the top tube pivot fell out everywhere. The other side are completely rusty. Anyone know how I go about replacing these?
Posted : 22/06/2015 7:41 pm
Someone surly, I know there's a few of you on here...
Posted : 22/06/2015 9:00 pm
 accu
bike components in germany sells them, complete with new ti screws and washers...
search for "syntace nadellager 301/601"
but you should check from which year/MK your frame is,
to be sure that it fits, they changed bearings and pivot diameter through the years
Posted : 22/06/2015 9:39 pm
Thanks Accu. It's a Mk10. I saw those, I thought those were the needle bearings for the shock mounts, not the main pivot built into the top tube?
Posted : 22/06/2015 10:29 pm
Those are indeed the alternative needle bearings for the shock eyes. I did some searching for info on the German forums but didn't find anything definitive. The only reference I got was telling someone to send the frame to Syntace to have them replaced! Not much help sorry.
Posted : 22/06/2015 10:41 pm
Found this, but unfortunately not much detail.
http://www.mtb-news.de/forum/t/bearing-press-for-liteville-301.742463/#post-12997054
Posted : 22/06/2015 11:22 pm
[img] http://www.mtb-news.de/forum/attachments/dsc_0303-jpg.390680/ [/img]
Thanks welshfarmer! At least it looks like they can be replaced... Above are the bearings that I need to change, image from that German forum. I'm really surprised theres not more info out there.
Mine look like this:
Posted : 23/06/2015 7:46 am
OP, would you consider selling your 160mm plates? I've got a MK11 frame
Posted : 23/06/2015 7:51 am
 anc
Hi bud. The exact same thing happened to the bearings on my MK10. I emailed Liteville to ask were I could buy them or if they would sell some direct. They sent me a updated set, bearings axle and bolts completely free of charge! They have modified it so it has a grease port in the bolt head to stop the corrosion issues. Worth a try before you buy out 😉
Posted : 23/06/2015 9:21 am
That is nice to hear anc. There is a real long thread on the Germasn forum about this rusty bearing issue
http://www.mtb-news.de/forum/t/nadellager-rostsuppe.612400/
Can probably use Google translate to get an idea of the gist of the topic
Posted : 23/06/2015 11:07 am
anc, that's great news, cheers. I've emailed them now. How did you drift the bearings out?
Hanrey, I'd be happy to sell them, email is in my profile.
Posted : 23/06/2015 11:15 am
 anc
They drift straight through, there's no shoulder to press the bearing onto. Pretty simple once you know that.. I didn't first attempt, tried to remove from the blind side thinking there'd be a shoulder..grrr :)) See the red frame above. Just make a note of where the old bearing sat and press the new ones in, nice and gently so as not to press too far.
Posted : 23/06/2015 11:41 am
