Busted FSA Chainset
[Closed] Busted FSA Chainset
[#1866482]
://www.flickr.com/photos/39913107@N07/4864478884/
I was out on my trusty Cross Check this evening when I had a bit of a 'mechanical moment'. The smallest chainring sheared off. I'm guessing the chainring bolts are made out of an alloy with the properties of stale cheese. It was a bit of a shock and frankly a bit of a crap end to my ride.
Has this happened to anyone else with an FSA chainset? Have I now found the reason why On One were offloading them so cheaply?
Posted : 05/08/2010 11:05 pm
bolt was probably loose
Posted : 05/08/2010 11:06 pm
 ton
this happened to me with a stronglight touring c/set...middle ring.
went over the bars and banged my shoulder bad.
Posted : 05/08/2010 11:07 pm
i have a fsa tech 2 type no probs with it and had it for 6months.
Posted : 05/08/2010 11:09 pm
I've never had a bolt on a chainset loosen itself before. If that was the cause it isn't something I would normally check for.
Should I now be paranoid and check my other bikes?
And why the hell have my skills in posting images suddenly deserted me?
Thankfully I was going quite slowly up a fairly steep hill so no over the handle bar adventures were involved.
Posted : 05/08/2010 11:12 pm
will you replace it or fix it.
Posted : 05/08/2010 11:15 pm
Well, the bb is running smoothly and the chainset was nice and light...guess I'll have to take it off at the weekend and narrow down what the cause was. If it can be fixed it will be a damn sight cheaper than replacing it.
Right nuisance.
Posted : 05/08/2010 11:18 pm
has the hole or thread been damaged????.
Posted : 05/08/2010 11:23 pm
Not had a proper chance to check yet, it was a bit late in the evening by the time I got back and I was a bit fed up with it all by then.
I'm going to leave the whole swearing at tools in the garage thing for tomorrow evening. Hopefully I can sort it.
Posted : 05/08/2010 11:30 pm
if you are not able to fix it, i mite be able to help, i work in the engineering trade i mite be able to sort it out if the frames not broken, if you cant fix it send me some info to my email and see what i can do.
Posted : 05/08/2010 11:41 pm
Ta, I'll see how I get on.
I seem to have had a week of problems with my bike and cycling in general.
If I can't fix it I suppose I could always fashion it into a throwing star and pretend I'm a ninja 😀
It would have to be a drunk fat ninja obviously...
Posted : 05/08/2010 11:45 pm
no probs just let me know.
Posted : 05/08/2010 11:48 pm
