Bulk tubeless tyre ...
[Closed] Bulk tubeless tyre plugs
[#7818711]
Does anyone know where you can buy multiples of the anchovies things for sensible money? I thought I'd found some on fleabay but they turned out to be for motorcycles and HUGE!
Looking for around 20 ish
Posted : 10/05/2016 10:49 am
Blimey I've used about 5 in the last 8 years of running tubeless!
I cut them half before use but even so 20's a lot of holes the sealant doesn't fill 🙂
Posted : 10/05/2016 10:51 am
Maxalami.de have an online shop where they sell 10x3.5mm packs for 10EUR and 5x6mm for 5EUR.
Posted : 10/05/2016 10:54 am
I've had a bit of a rush on them, lots of flinty bits in dusty trails wrecking havoc. I've used 2 on one ride recently. Good call on cutting them but didn't think of that before I was down to 1
Posted : 10/05/2016 11:00 am
The motorcycle/car ones are made up of lots of skinny ones lightly glued together.
If you pick at the end of a big one you will find the small ends, pull along the length and then cut in half for extra yield.
Posted : 10/05/2016 11:03 am
I thought we had it there but sadly the delivered ones seem to be solid, certainly not peeling apart
Posted : 10/05/2016 11:07 am
Lummox - Member
Could be worse, put 4 holes in my tyres in one hit last weekend. Also now on the hunt for a supply of repair kit
Posted : 10/05/2016 11:16 am
Thanks out for the link, but as I indicated in the first post (although maybe not crystal clear) I have purchased some from eBay and they have been delivered but are far too large for bicycle tyres, they're for cars/motorcycles.
Rather than making the same mistake again I was after a definate supplier
Posted : 10/05/2016 11:45 am
Even if you tease the end of the big one open with a knife, starting to slice it lengthways?
The ones I have seem pretty solid/dense at first but once you get the first piece loose they are like a rubbery rope with the strands spiralling along the length.
ETA: 2? 4? Amateurs.
(Yes, slime filled, but it can only do so much.)
Posted : 10/05/2016 12:18 pm
Thorns don't count
Posted : 10/05/2016 12:48 pm
I got 10 of the 4mm ones recently for 2.50 delivered. You must've ordered the 7mm ones, that's your mistake. Plenty of the right size on ebay.
Posted : 10/05/2016 1:40 pm
Yeah just had look for these myself and found 2 sizes. Here are some 4mm ones: [url= http://www.ebay.co.uk/itm/TUBELESS-TYRE-REPAIR-KIT-INSERTS-PLUGS-STRINGS-4-x-20-STRIPS-/141035220559?hash=item20d65aae4f ]http://www.ebay.co.uk/itm/TUBELESS-TYRE-REPAIR-KIT-INSERTS-PLUGS-STRINGS-4-x-20-STRIPS-/141035220559?hash=item20d65aae4f[/url]
Posted : 10/05/2016 1:50 pm
