'Budget' 29er fork ...
[Closed] 'Budget' 29er fork (120mm)
[#11332952]
My Bizango is ready for a new fork; they can be boost or non boost/ straight steerer or tapered.
Any recommendations for under £300?
My Google-ing has found;
-Manitou Markhors (@ decathlon)
-RS Judy or Recon
Or should i wait a bit/ save up and get some RS Revelations when they are back in stock? These would cost nearly as much as the bike cost me though.
Posted : 11/08/2020 4:39 pm
Mate bought these off a PSA on here .
hattps://www.probikeshop.com/en/gb/rockshox-reba-motion-control-rl-29-130-mm-fork-solo-air-15-mm-axle-boost-51-mm-offset-black-2019/151325.html
Posted : 11/08/2020 5:12 pm
Reba. Often come up new for near that or easy to find secondhand.
Posted : 11/08/2020 5:37 pm
How long a steerer do you need, LBS has some sets of Reba removed from a new bikes.
Edit Forget that they've only got 27.5 left.
Posted : 11/08/2020 5:46 pm
Cheeky DM sent 😉
Posted : 11/08/2020 5:58 pm
Thanks guys. Just gone for a set of RS Reba from Probikeshop. Just need an external lower headset cup now.
Posted : 11/08/2020 6:02 pm
 Earl
Snaps - can you pm me details
Posted : 11/08/2020 10:26 pm
I have a brand new boxed Reba 130mm 29er boost for sale.
07941418756
Posted : 11/08/2020 10:45 pm
Just be aware that 130mm Rebas CANNOT be spaced down to 120mm or below, only up to 150mm max.
Been there, done that (I posted up the PSA).
Posted : 11/08/2020 11:11 pm
 nuke
Can't see how that can be correct. Air shafts are just longer/shorter shafts
Posted : 12/08/2020 12:33 am
I have a brand new Judy fork for sale.
Posted : 12/08/2020 7:52 am
Yes, the air shafts are different lengths BUT the dimensions are ever so slightly different. I bought a 120mm air shaft and it would not fit (too big).
I really couldn't work it out until I checked on the Rockshox website and it is clear on there that the 130-150 chassis is not compatible with the 80-120mm chassis.
Crazy, but I can only assume that the stanchion legs on the 130mm-150mm are a tiny bit thicker to increase stiffness.
As I say, been there, done that....
Posted : 12/08/2020 8:24 am
