Broken Fox Rebound ...
[Closed] Broken Fox Rebound Shaft
[#7112880]
Opened up my 32s after the rebound adjuster started just spinning around and turns out the rebound shaft has stripped. The two tabs that locate in the slot of the rebound needle have sheared off. Could I grind/file the shaft to create a slot, it would end up being 1mm shorter but I cant see that affecting it too much.
Cant seem to embed photos from dropbox but heres two photos of the broken shaft:
https://www.dropbox.com/sc/hoy0okyouq6obrz/AABR55wNVwO69J2bCbBEsOjua
https://www.dropbox.com/sc/lcbkxpkrqom00uc/AAAZKBItJoHjzWX9wzjrzYV6a
Posted : 05/06/2015 4:31 pm
