Brand X Dropper spa...
[Closed] Brand X Dropper spares
[#11669461]
I have just taken delivery of a Brand X Dropper from tri sport resort on EBay which I believe is Wiggle.
I thought it was coming without a cable but It's arrived without the cable nut & the cable screw at the lever end, I've had a Google for the parts ndeed & can't find anywhere that has them in stock, has anyone managed to "bodge" or know where could source alternatives?
Posted : 10/01/2021 9:44 pm
Check the size, but it’s a great solderless cable nipple you need.
8Pcs Solderless Cable Nipples 5mm Throttle Choke for Motorcycle Scooter Quad Mower https://www.amazon.co.uk/dp/B07T6YCNWH/ref=cm_sw_r_cp_api_fabc_RR2-FbRNZAY0V?_encoding=UTF8&psc=1
Posted : 10/01/2021 10:04 pm
Or you can bodge one with a dremel from the copper part of an electrical con block or/ plug etc.
Jimmy's option is easier.👍
Posted : 10/01/2021 10:11 pm
Knew that I'd get a fix on here, cheers!
I presume that if I buy one for the actuator and lever if it's screwed tight enough the cable won't slip!
Posted : 10/01/2021 11:19 pm
I would just contact them and ask for one?
Posted : 10/01/2021 11:30 pm
I swapped mine out to another brand I might have what you need in the tool box
Pm me
Posted : 11/01/2021 12:15 am
