Brand-X Ascend II E...
[Closed] Brand-X Ascend II External Dropper Post
[#10971652]
Hi all,
Just bought myself this dropper post for chrimbo. Was just wondering is there a way to test it's working ok before I install the cable etc?
Cheers.
Posted : 20/12/2019 1:12 pm
Pull the little cam where cable attaches to operate !
Posted : 20/12/2019 1:45 pm
Thanks will take a look when I can, I assume it's safe to do this without causing any damage?
Posted : 20/12/2019 2:22 pm
Not at all all your doing is replicating what cable does 🙂
Posted : 20/12/2019 3:05 pm
Why would you assume that it was anything other than working fine ? Seems like a bizarre way of going about things or perhaps I am just an optimist . Would you check that your brake pads weren't contaminated before fitting them etc ?
Posted : 20/12/2019 7:43 pm
It's just thats its quite an expensive part and didn't want to go through the trouble of fitting it to find it was faulty.
Posted : 21/12/2019 1:56 am
There is no right or wrong about checking a part is functioning before fitting.👍
They are great droppers so all should be good.
Posted : 21/12/2019 2:23 am
I always check any new parts over before fitting them. Imo its good practice and saves time in fitting a faulty part. It takes 30 seconds but could save hours of fitting, finding out it doesn’t work then removal.
Posted : 21/12/2019 8:54 am
They do have some play in them from new! It's a bit more than I'd like in an ideal world, but liveable given they are cheapish and reasonably reliable compared to other, often more expensive offerings.
I don't think there is anything better at the price (usually on sale for 80-90 quid) and it's been that way for a few years now!
Posted : 22/12/2019 1:55 am
 tdog
Mine has loads of play of all sorts since new
Am i bovered, no cause it does the job!
Save £200 and get one then you can upgrade lever to a fancy one as that makes more difference on droppers ime
Posted : 22/12/2019 6:15 pm
Started installing it today. Doesn’t look like i’m going to be able to get the 1x lever to work next to my front shifter.
Anyone got a 2x lever that they don’t want, rather not pay another £25 for another lever.
Posted : 26/12/2019 11:23 pm
Also, is there a way to rotate the cable actuator/collar anti-clockwise so that it’s slightly more hidden from view. There is a small screw on the back of this collar which I tried loosening but it still wouldn’t move.
Any ideas? Perhaps undo it more?
Posted : 27/12/2019 12:41 am
I run mine on the RH side above the bar. Doesn't look tidy, but it works.
Not as far as I know, I assumed it was designed to sit to the side to allow the cable to be routed around the side of the top tube. I wouldn't start unscrewing things unless I knew exactly what they were there for.
Posted : 27/12/2019 12:56 am
I think I’ve got the 2x/cx style lever somewhere, pm me and I’ll go look when it’s daylight 👍
Posted : 27/12/2019 5:29 am
PM sent!
Posted : 27/12/2019 12:02 pm
A shop locally is selling the Giant Switch 2X lever for £18.99, anyone know if this would be compatible??
Posted : 27/12/2019 5:55 pm
Think you’ll be fine with that -
https://www.mbr.co.uk/how-to-2/mix-dropper-remote-lever-378762
Posted : 27/12/2019 11:04 pm
Managed to get a 2x lever from a local bike shop and have now finished setting it up. Going for first ride with it on today!
Posted : 29/12/2019 12:47 pm
