Brake adaptors for ...
[Closed] Brake adaptors for 20mm questions
[#2928268]
Ok, need some adaptors for a set of Hayes Stroker Trail.
So brake caliper is 74mm (Post mount?)
I need to fit on the rear for 180mm disc, rear mount point on frame is 51mm (IS?), any idea where from as i guess its IS to Post mount i need?
I also will have a 20mm maxle fork i need to mount a 180mm disc front, so do i need an adaptor that is designed for a 20mm maxle or is it just the same?
Posted : 09/07/2011 10:50 am
Strokers are Post mount:
So you need a "Rear 180mm PM to IS adapter", a per the type 4 adapter from Superstar components (not a recommendation to use them, but the have a picture with all the different mount available):
http://superstar.tibolts.co.uk/product_info.php?cPath=57&products_id=359
The 20mm maxle has nothing to do with the fork mount, it's still either POST or IS. Though (obviously) you need a "front" adapter not a "rear"
Posted : 09/07/2011 11:53 am
Z1ppy....thank you for that 8)
Posted : 09/07/2011 12:06 pm
