Bottom Bracket Spac...
[Closed] Bottom Bracket Spacers
[#9353723]
To lower the gearing on my croix de fer, I'm changing the crank set from a road compact (Shimano 105) to a XT.
The bottom tube is 68mm, so I need 3 spacers, and my understanding is that I should put 2 spacers on the drive side. But the front derailleur won't quite reach for the big ring when I do this.
So... is there any harm putting a single spacer on the drive side and a pair on the non drive side?
Posted : 29/05/2017 9:58 pm
No harm at all (done it myself once).
You're probably OK given that it's only a 2.5mm difference, but few things to watch for:
1) Make sure the chain-rings don't end up too close to the chainstay otherwise there's a risk of damage if you ever get chainsuck
2) Your FD could end up closer to the tyre than before (probably not an issue on a CX bike)
3) Your RH heel might catch the chainstay
Also, you might be better off with an MTB FD if the chainrings are smaller.
Posted : 29/05/2017 10:10 pm
Cheers DJ... I'll take a look at those, especially number 1
... am I looking to make sure the chain will happily slide between the little chain ring and the chain stay?
If that's an issue, then a new derailleur required I guess.
Posted : 29/05/2017 10:13 pm
What about a CX chainset.?
Posted : 29/05/2017 10:46 pm
cheers NoW... I had looked at teh CX options too, but decided that I'm going really low on the gearing (38/24) to protect my knees on the hills when the bike's loaded up for longer trips... and still hit 40kph at ~90 cadence (beyond which I just enjoy coasting on that bike).
Posted : 30/05/2017 8:28 am
I put an XT chainset on my CdF, 42/28. It works well with the same FD, Sora in this case.
Posted : 30/05/2017 12:56 pm
Tested it out tonight, and seems to be fine - thanks for the input everyone.
Posted : 30/05/2017 10:24 pm
Just be aware that road hollowtech bottom bracket cups are 10mm and Mtb cups are 11mm wide. This caught me out when I changed to 105cranks with an 8000XT bb
Although going to an Mtb crank [i]could[/i] be okay providing the plastic pre load collar can go deep enough into the axle threads to preload correctly.
Posted : 31/05/2017 12:26 am
Cheers Rusty - I have changed the bottom bracket too
Posted : 31/05/2017 9:46 am
