Bottom bracket - Gr...
[Closed] Bottom bracket - Grease or thread lock ?
[#8397661]
Sure this gets asked a bit... but... Aluminium frame (Giant Anthem), press fit BB92 XT bottom bracket going in. Should I apply a thin layer of grease or thread lock/loctite ? seems to be conflicting views. I am favouring grease.
Posted : 13/03/2017 10:11 pm
Just a touch of grease.
Posted : 13/03/2017 10:16 pm
Copper slip .
Posted : 13/03/2017 10:19 pm
CheesybeanZ
Copper slip .
+1
Posted : 13/03/2017 10:22 pm
Smear of grease on the shell
Posted : 13/03/2017 10:29 pm
Any grease or copper slip will be fine, but not needed.
Lots of people will of course tell you that what they use is the best.
Posted : 13/03/2017 10:48 pm
Red Loctite...
Not really, just use a dab of grease.
Posted : 14/03/2017 10:19 am
A product that by its very design has to be removed and replaced at some point...Why would you want to glue it in?
Posted : 14/03/2017 10:23 am
Grease/copper slip.
Posted : 14/03/2017 10:28 am
But what I use is the best... a threaded bottom bracket 😈
Posted : 14/03/2017 10:29 am
Copper slip is for things that get hot. You're not going to pedal fast enough to generate enough heat to justify it.
Grease.
Posted : 14/03/2017 10:35 am
Copper slip is an anti seize compound, so heat causes the seizing.
TBH grease or copper slip would be fine. I've used both and never had any issues.
Anything is better than putting it in dry (fnaaarr!).
Posted : 14/03/2017 11:27 am
coppaslip - never ever assemble any joint dry. Grease where you remove if often. coppa slip if not removed very often, locktite if its at risk of coming undone
coppaslip is not just for things that get hot - its also good for preventing corrosion with dissimilar metals
Posted : 14/03/2017 12:11 pm
Is it? Genuine question.
Posted : 14/03/2017 12:23 pm
Thats my understanding - it prevents galvanic corrosion ie steel screws getting stuck in alloy castings. I use it everywhere on my bikes and have never suffered a seized bolt
Posted : 14/03/2017 12:37 pm
yes it is
Posted : 14/03/2017 12:59 pm
Interesting. Never thought of using it on anything other than brakes etc.
Posted : 14/03/2017 2:26 pm
[quote=tjagain ]coppaslip is not just for things that get hot - its also good for preventing corrosion with dissimilar metals
Also known as Ti-prep for this reason.
Posted : 14/03/2017 2:28 pm
