My bike (Yeti ASR-SL with reba race) currently has standard Shimano XT QR hubs.
I'm looking to upgrade the wheels and thinking about going for one of the bolt on systems to improve stiffness.
I don't want to add any weight though really.
Can anyone give a run through of the systems out there to fit my frame and forks?
The last time I had bolt on wheels was on my Raleigh Mustang when I was 11.
Am I looking for MAXLE? That appears to be a big QR.
Can you get these for the rear?
You need an appropriate frame and fork for any of the bolt through systems.
If you went for DT, Specialized/Roval or Hope hubs (sure there are others) you can use their 9mm QR, but you can't fit Maxle/Maxle-Lite/QR15 etc etc without changing your forks, nor 142mm rear without changing your frame.
You can get 9mm hubs, and you can fit 9mm axles to standard QR frame/forks. They're not bolt through but might improve stiffness
Did you read my post?
What njee20 said. You could try the DTSwiss ratchet QR skewers, which allow a theoretically higher clamp force to be exerted. But they're fragile and expensive, and I don't think you'd really notice the difference (except in your wallet).
Thanks njee20, seems there's no true bolt through system for standard frames.
How about these then?
http://www.on-one.co.uk/i/q/WPOOMAX/on_one_max_adaptable_maxle_wheelset_
OR
http://superstar.tibolts.co.uk/product_info.php?cPath=40&products_id=348
They seem to be able to run a 9mm big QR up front and a 10mm big QR in the rear - will those fit my frame and forks?
I know they aren't bolt through as I asked for! but its the kind of thing I was thinking off to stiffen things up a little. will i notice ANY difference!?!
I'll have to weigh my current wheels (XT on x317) to see if there's any weight difference.
you can run a 10mm bolt up axle in most qr dropouts, that'll stiffen up the rear. at the front-end, just buy a decent fork.
If you're buying "a decent fork" you may as well get a Maxle/QR15 one 🙄
They seem to be able to run a 9mm big QR up front and a 10mm big QR in the rear - will those fit my frame and forks?I know they aren't bolt through as I asked for! but its the kind of thing I was thinking off to stiffen things up a little. will i notice ANY difference!?!
Yes, and I would expect so.
I don't think you can add bolt-through axles to either the front or rear hubs so you're looking at a new fork and wheelset really.
Reba or Sid with maxle lite (and preferably Blackbox damping) would be what I would go for.
Hope Hoops with Stans CRest rims for the wheels.
£270ish for the wheels, £400-500 for the fork if you shop around. Maybe it's new bike time?
