Sunday afternoon.....
Picked up a used duo bike trailer for the little un's and its currently got 20 x 1.75 tyres.. (the trailers in excellent condition)
Looks like I may need to replace one of the tubes, which got me thinking..
There's loads of clearance, so could put a 2.2 width tyre on which should increase the smoothness of the ride or will it just make too much drag ?
Im thinking its more about the pressure than tyre width ??
Sunday afternoon thoughts ?
Comfort is about pressure, but you need a wider tyre to run a lower pressure without risking pinch flats.
SChwalbe Mow Joe. Lightest 20" high(ish) volume tyre with trail tread.
Otherwise there are some pretty big volume semi slick bmx race/dirt tyres if you're just off round the pea gravel.
Thanks for the advice -- think I will go for some BMX type ones I have seen.
