Bib-Knickers
[Closed] Bib-Knickers
[#1061696]
Do people use bibs for general mtb-ing?
I would like some 3/4 undershorts and the majority seem to be bibs - what are the advantages/disadvantages over just shorts? I will be wearing them under baggies and base-layer tops (and a jacket in the wet).
Posted : 21/11/2009 10:39 pm
Advantages?
Warm Kidneys as you don't get "that" gap.
No-one get to see yer brickies' Clevage.
Disadvantages?
If you need to go for a piss, then make sure you leave yerself enough time...
Posted : 21/11/2009 10:43 pm
As Teetosugars says. Just dead comfy
Posted : 21/11/2009 11:27 pm
They're comfier, and the pad stays put better which means less plum-rubbage. They are much more comfortable.
Posted : 21/11/2009 11:28 pm
I use 3/4 bib knickers for most of my autumn/winter/spring riding, always with baggies over on the mtb and none when on the road bike. AS above very comfy and no gap between shirt.
I have tried many inc Gore, DHB, older Endura and Pearl Izumi, my current faves are the new Endura FS260 bibs
Posted : 21/11/2009 11:40 pm
 jond
B*gger bib knickers - when it's chilly just go for bib longs and have done with it - peel the whole lot off and yer legs are pretty damn clean - which is handy if you've got to get in a car without a hose-down.
Forget the baggies, waste of time IMO.
(Then again, I R XC jeyboy..)
Roubaix-stylee top (or thermal top under s/s jersey) with roubaix bib longs (Lusso stuff's good) normally do me for most UK weather from about 15 degrees down to freezing, and I don't bother with a jacket unless it's chucking it down). Any warmer than that and lycra tights with bib shorts (or shorts+braces) helps keep my rubbishy knees a little warmer - and also have the dirt peel-off advantage 🙂
I *have* tried on bib knickers once - but found the elastic sufficiently tight that I felt like my calves were gonna drop off/explode - wouldn't have helped the varicose veins much either 😮 But I'm sure they're not all like that.
Posted : 22/11/2009 4:32 am
Specialized RBX bib knickers are the cat's pyjamas, can't recommend them enough
Posted : 22/11/2009 10:00 am
Can't fault DHB
Posted : 22/11/2009 10:43 am
Have been using bib shorts/tights & 3/4 for decades and I cant imagine not having the bib bit as the shorts would always slip down?
But what is it with the thickness of the pads in some of the new stuff its bloody massive! DHB included
Posted : 22/11/2009 12:11 pm
I always wear 3/4 bibs. Warm back, clean legs.
I've got an On-One pair. They are quite low at the front which helps with alfresco weeing.
Posted : 22/11/2009 12:14 pm
ground effect do a good pair of non-bib 3/4's. montezumas i think
Posted : 22/11/2009 12:18 pm
Harry_the_Spider - Member
Good reminder Harry I had a pair of the On-Ones that got shredded in a crash, bought some Altura ones and the pad was like 3 nappies stuck together.
Don't know why I didn't just replace like with like?
Posted : 22/11/2009 12:45 pm
 jose
The 3/4 dhb ones I have are great for wintern riding, worn under baggys and a long sleeve base layer. Advantages for me are warmer for your kidneys and less clothing joins under the bottom of your bag. Disadvantage is also being warm - I dislike being too hot on climbs, it makes me slow *ahem*.
Though I wish I'd got womens ones... (I know that wont affect most of you)! Any recommendations for 3/4 length womens bib knickers?? The only ones I can find <£60 in 5 mins quick look are dhb Ladies Merston Bib Tights, but they are full length.
Posted : 22/11/2009 1:04 pm
Knickers combined with waterproof baggy outer were perfect for my hack around Cann this morning.
Although I wear roubaix tights for road, I find them just too warm for mtb, even in the middle of Winter. Of course, it never really gets that cold in the westcountry. I might be thinking differently if I lived in Yorkshire.
Posted : 22/11/2009 1:07 pm
