Best track pump for...
[Closed] Best track pump for tubeless conversion
[#1065004]
Ok after busting a lung over the weekend trying to do a tubeless conversion using my trusty Silca track pump the time has come for something that shifts a larger volume of air in one stroke. What's the best track pump (value for money) that'll get the job done. I know a small cheap compressor would've made th job so much easier. 🙂
Posted : 23/11/2009 10:06 am
 Smee
joe blow works really well for me.
Posted : 23/11/2009 10:09 am
Use co2 inflator for the initial seating of the tyre (it goes up instantly), leave for 10 mins then take valve out (careful you dont pull bead off rim) add sealant, replace valve and it should inflate easily with your track pump.
Posted : 23/11/2009 1:40 pm
