Best rear light usi...
Best rear light using a fixed bracket?
 jeb
[#13044850]
yep, a rear light with a bracket, kind of quick connection, no rubber strap mount.....
Posted : 16/11/2023 6:02 pm
Cateye have always done excellent rear light mounts. I even use two rear light brackets to mount my rack on the recumbent! And every light fits the same bracket. You can even buy an adaptor for their Rapid strap-on lights (Rapids) to use with their square mount - have one of those too. Saddle, seat post and seat stay brackets are all available.
Garmin Varia RTL515 mount uses the standard Garmin quarter turn and is available as a dedicated seatpost mount (I have 4 to swap between bikes). Device comes with a strap-on bracket which is fine for my two aero seatpost race bikes, but the seatpost bracket is excellent.
Posted : 16/11/2023 6:57 pm
no idea what model it is but I've got a Moon one that has a mount that's clamped onto the seat rails. Works well and the light is great.
Only reservation would be if you wear a long coat or backpack that it might obscure the light somewhat as it's right up under the seat.  this alos makes it a little fiddly to install/remove but I'm happy to live with that because it's so tidy.
Posted : 17/11/2023 10:14 am
Hope Districts used to be a bayonet mount to a fixed clamp, not sure if that’s an option anymore though.
Posted : 17/11/2023 10:18 am
The Moon that I posted in the other thread has a really good saddle mount as mentioned above. I'll get a pic in a bit
Posted : 17/11/2023 10:23 am
20231117_093704
Posted : 17/11/2023 10:38 am
Most of the 'better' Moons come with saddle clamp, bungee clamp and fork leg/tube/bungee with bracket clamp.
Posted : 17/11/2023 10:40 am
Bought a moon nebula the other day. the mounts are ace as mentioned above
Posted : 17/11/2023 11:14 am
