best mudguards for ...
[Closed] best mudguards for 26" rigid commuter?
 tor5
[#6559214]
I'm fed up of getting soaked on the commute, so can anyone recommend mudguards for a 26" MTB? There are mounts at the rear and it's fitted with an on-one rigid fork (steel), IIRC there are no mounts on that.
Thanks!
Posted : 16/10/2014 1:35 pm
IIRC I used SKS Bluemels or Chromoplastics on mine, very good. There's ways to bodge up mounts on the fork, using p-clips or similiar.
Posted : 16/10/2014 1:41 pm
SKS clip on black plastic guards can be had for under a tenner and do the job very well. I drilled my fork (Planet X but same as On One) to mount the bracket and it hasn't killed me in the 8 years since.
Posted : 16/10/2014 1:42 pm
Or Crud Raceguard set with extra Mudhugger on front. Positioning the Crud Catcher quote low (more less just above bottle cage height) helps keeping the "rider's front end" clean 😆 This is my Autumn-Winter set-up not just for commuting.
Posted : 16/10/2014 1:49 pm
I've just hit the buy button on SKS Cromoplastics at £27.99 from CRC
Never have I been more excited about such a dull object 😳
Posted : 16/10/2014 2:11 pm
Chromoplastics all the way for permanent fit guards, solid reliable and surprisingly resilient/strong.
Can be a bit fiddly to fit if you're a bit of a fumbler, but not really that bad, and once fitted they just work.
Posted : 16/10/2014 2:15 pm
SKS bluemels here, a bit fiddly to fit, but completely problem free once done. I bought a mudflap extension for the rear guard to keep spray off the baby trailer.
Posted : 16/10/2014 2:20 pm
 tor5
Thanks peeps, will order tonight. Chances of reverse-mockers causing a couple of weeks of dry weather? Or does it not work for rain gear?
Posted : 16/10/2014 7:51 pm
Does anyone actually know what the difference is between bluemels and cromoplastics? Buggered if I know which one is which, got one set of each...
Posted : 16/10/2014 8:18 pm
If you're commuting on a dedicated bike don't waste your time with clip ons. Get the proper job, they are so much better than clipon and IMO look better / tidier.
Posted : 16/10/2014 8:26 pm
I got a set of the SKS Commuter guards cheap from a PSA but wouldn't buy them again as they're a bit flimsy. Bluemels look much better.
Posted : 16/10/2014 8:35 pm
Northwind:
Chromoplastics have 2 metal strips in which allow you to power a light by using the metal strips as wires.
bluemels do not have this, and are often a little cheaper as a result.
Posted : 16/10/2014 9:35 pm
Ah! Cool. Pointless for me, but cool. Cheers!
Posted : 16/10/2014 10:30 pm
