Best lube
[Closed] Best lube
[#8222948]
Title for attention. For rockshox seals and a monarch plus that's stuck halfway in travel so time for some servicing. Thanks
Posted : 12/12/2016 12:17 am
Depends.... (as does everything) dry, dusty, claggy, road or mtb? long rides short rides, are you good at looking after your bike?
Rock n Roll Extreme here but my conditions are probably different
Posted : 12/12/2016 12:19 am
Butter
Posted : 12/12/2016 12:20 am
Rest of message must not of saved. It's for mostly rockshox forks and a monarch plus which already needs a service as it's stuck half compressed
Posted : 12/12/2016 12:22 am
Chain lube, stanchion lube, KY?
NM, stealth edit changed the post.
Posted : 12/12/2016 12:24 am
good quality fork oil? Get it from a motorbike shop - cheaper AND better quality than that sold for cycles
Posted : 12/12/2016 1:12 am
Depends a lot on if you want the weights to be right, can't find the chart that avalanche had but the weight variation over oils all with the same lable was huge. I used whatever I could get cheaply for old/cheap forks but use what is specced for the nice stuff (the avalance stuff specs a particular brand which happens to be motorbike stuff) for the seals something like RS Butter https://www.sram.com/sram/mountain/products/sram-butter-grease - others available.
Also something to clean the insides out.
Posted : 12/12/2016 1:18 am
I use what the manufacturers recommend, I just don't usually buy it in their labelled bottles- I can't remember off the top of my head but I think the current Fox oils are torco and rockshox is maxima (fox used to have one that was a silkolene but I think they swapped). A litre of rockshox 15W is £17 at Tredz, a litre of what seems to be the same stuff branded maxima with a black bottle instead of red is £7.
OTOH, the volumes you use are pretty small so if you want an easy life and presence of mind, it's not a terrible option to get the expensive "own brand"
mikewsmith - Member
Here we go:
http://www.peterverdone.com/wiki/index.php?title=Suspension_Fluid
Posted : 12/12/2016 1:36 am
for your shox / fork
float fluid
slick honey
prepm
any will do
Posted : 12/12/2016 4:22 pm
