best budget worksho...
[Closed] best budget workshop stand ?
[#4134534]
any advice ? anyone used the decathlon elite workstand ?
Posted : 05/07/2012 2:31 pm
 DrP
I've just picked up the £30 Lidl one on a whim!
I've currently got a 2-legged folding one - this looks a bit sturdier - I might try to make a bastard lovechild of the two....
DrP
Posted : 05/07/2012 2:34 pm
Lidl in the shops today 29.99
ribble one for £50, solid as a moderately floppy rock. Holds my 35lb pitch without wobling about for 99% of jobs, probably wouldn't trust it for bashing headsets out though*.
*best way I've found was to put the upper race in a vice, and suppourt the back of the bike in a workstand, then knock the lwer race out, which in the process tended to loosen the top race sufficiently.
Posted : 05/07/2012 2:40 pm
 br
Buy cheap, buy twice...
Got a Park 2nd time around 😳
Posted : 05/07/2012 6:06 pm
I'm with b r on this.
tried quite a few, that lidl one is a POS as it is, needs a few modifications to make it average.
best buy at the moment is the park PCS9, you can get one from winstanleys for about £85.
if you can however, get the PCS10, it's a few quid more, but you can accessorize. I particularly like the wheel trueing stand that mounts on the rear of the stand.
Posted : 05/07/2012 7:14 pm
Just got the Lidl one. Indexed the gears on my Coyote Dual. First impressions are that it could do to be a little more sturdy but let's see. It's my first workstand so I've nothing to judge it against.
Posted : 05/07/2012 10:56 pm
Had loads over the years and the Decathlon one is light years ahead. Stable and robust. Can't recommend it enough.
Posted : 06/07/2012 7:56 am
Got a Decathlon one, too - the bike sits on it, rather than hanging from a clamp - seems to work fine. I use it with both road bike and mtb, you don't need to adjust it or anything.
No doubt a more expensive "pro-level" stand would last longer, but I don't use it enough to justify that kind of expense.
Posted : 06/07/2012 7:59 am
