Bearings
[Closed] Bearings
[#5095881]
I stripped down my Tracer 2 tonight to change the bearings in the upper link. While it was stripped I checked the lower bearings. Moving the rear triangle they felt a bit notchy so I stripped the bottom link.
The funny thing is that the bearings in the frame are fine. So, I cleaned everything up and put it back together but if feels notchy again. Is this notchy feeling normal? Due to over tightening? Am I making some kind of school-boy error?
Thanks
Posted : 23/04/2013 9:33 pm
Are you missing some kind of spacers or washers? If so, you may be forcing the bearings out of alignment.
Posted : 23/04/2013 10:29 pm
and it won't make **** all difference to the ride!
Posted : 23/04/2013 10:34 pm
Nope it's all assembled correctly, perhaps I've just over tightened the main pivot bolts.
Do you mean it's normal and nothing to worry about?
Posted : 24/04/2013 9:57 am
daft question, but the notch isn't at the start of the stroke is it? (the top bushing on the shock worn?)
Have you isolated the shock from the suspension, and still seen if the fault occurs, though it may also make it easier to find the the source of the fault.
Posted : 24/04/2013 10:05 am
[b]z1ppy[/b] – The shock is removed from frame and upper link is unattached. It's definitely just the lower bearings when only the lower link is assembled.
All four bearings are smooth when the pivot bolts are removed. I'm thinking I may have just over tightened them as per [b]coatesy[/b] comment above.
Posted : 24/04/2013 11:06 am
I did my tracer 2 last week and used the torque settings in this thread:
http://forums.mtbr.com/intense/intense-tracer-2-torque-table-786859.html
I did all the bearings though, the old bottom ones felt alright out of the frame but were a bit rough in the frame.
Posted : 24/04/2013 12:32 pm
[b]sandal100[/b] Thanks for the torque settings. Where did you get the lower bearings from? Are they the metal seal version?
Posted : 24/04/2013 12:51 pm
I got the 7902 enduro max bearings from mb bearings. The ones in the tracer are only sealed on the outside, no seal on the inside, presumably so you can get the grease in there. The enduro max are rubber sealed on both sides. I did consider picking it out but didn't want to damage the inners.
For the top shoulder bolts I torqued them to the lowest what it said, worked out to 21nm I think with blue loctite. I also added a bit of blue loctite to the bolts in the expanding bung, I didn't add any to the 8mm through bolt
I can also recommend the 6901 bearing tool from superstar for changing the top link bolts, took a few minutes to do all four.
Posted : 24/04/2013 1:02 pm
sandal100.. Where did you get the lower bearings from?
Bearings with a metal [u]shield[/u] are not [u]sealed[/u] they are [u]shielded[/u]
Bearings with a rubber [u]seal[/u] are [u]sealed[/u]
Posted : 24/04/2013 1:14 pm
Thanks for the tip, the ones in the rear triangle are easy enough to do in a vice, the that top link is a bit trickier.
Posted : 24/04/2013 1:16 pm
