Bearing - Too much ...
[Closed] Bearing - Too much grease?
[#582094]
Can you pack bearings with too much grease?
Posted : 26/05/2009 11:55 pm
Depends-if the grease is too thick-sticky making the bearing sluggish.
If you really pack them-use a fine grease that still has the properties/protection you need.
In cup/cone wheel bearings-I pack them fully-probably wasting grease.
Checking for play is a pain with over greased hubs with top end grease as the will still turn if overtightened.
Just don't go mental.
Whats the application?
Posted : 27/05/2009 12:00 am
loose or open bearings I always pack full. Sealed bearings are just left as they come from the factory
Posted : 27/05/2009 12:02 am
They are the bearings on my HT2 bottom bracket. I had a Superstar BB on for a year and it spun round very freely... until the bearing started to fall apart at the weekend. So I put the HT2 BB on because apart from the fact that it was a bit sluggish it was still in excellent condition.
Posted : 27/05/2009 1:00 pm
