Bearing press tools...
[Closed] Bearing press tools, possible to buy?
[#6425205]
I have a rear hub which it seems the bearing housing is right at the small end of the tolerance, which makes the normal tooling, (i.e. sockets, stud bar and nuts/washers) a right bastard to keep straight and on the outer race.
Is it possible to purchase proper press tools from somewhere? Like the Park ones I have for press fit bottom bracket, or do I need to get some made up at an engineering shop?
Ta.
Posted : 19/08/2014 8:50 pm
 LoCo
RRP (i think) do a very good kit, exspensive though
Posted : 19/08/2014 9:24 pm
mate with a lathe?
Posted : 19/08/2014 9:26 pm
 LoCo
yep we turn stuff up as necessary, don't offer the machining service though as not enough time (still at workshop now (coffee break))
Posted : 19/08/2014 9:30 pm
Loco, spot on, that's superb. Yes the press is expensive but the adaptors aren't too bad.
Don't have a mate with a lathe and don't do enough with that sort of supplier at work not to ask for a favour unfortunately. Hive mind to the rescue again!!
edit - and hope you get knocked off soon. Late night!
Posted : 19/08/2014 10:13 pm
we have a lathe and we made some of these ........its becoming amazing the things people will buy, never realised till now
Posted : 19/08/2014 10:17 pm
Bocca bearings in usa do one that covers lots of sizes, cost me £40 odd including rm charge and duty etc
Posted : 19/08/2014 10:19 pm
 JoeG
[url= http://wheelsmfg.com/consumer-bearing-press.html ]http://wheelsmfg.com/consumer-bearing-press.html[/url]
[url= http://www.bocabearings.com/bearing-lube-tools-more/tools/bike-bearing-installer ]http://www.bocabearings.com/bearing-lube-tools-more/tools/bike-bearing-installer[/url]
[url= http://www.superstarcomponents.com/en/bearing-removal-fitting-tool.htm ]http://www.superstarcomponents.com/en/bearing-removal-fitting-tool.htm[/url]
[url= http://www.enduroforkseals.com/id176.html ]http://www.enduroforkseals.com/id176.html[/url]
Posted : 20/08/2014 2:32 am
press? Just get the right sized drift (about £5) and a big bolt, some spacers, some thick washers, and the correct nut.
Posted : 20/08/2014 7:34 am
On one were doing a press plus lots of drifts for a good price recently.
Posted : 20/08/2014 8:39 am
PGP got a link to those 'drifts'?
I bought to Bocca thinking it looked like just the job & not too expensive, ended up costing £45 in the end as RM added £15 onto of the £30 purchase price. I'm not impressed (especially @ RM), seems to work well enough but all the sizes are odd numbers & come in pairs, so I've found one side fit the bearing but the other is bigger than your hole (eg: freewheel) you can't use it to push the bearing into place. Wish I'd saved the money and spent it on the Wheels kit, pity as it does have potential to be a cheap and useful bit of kit.
Posted : 20/08/2014 9:37 am
Thanks for all the links and suggestions, I'm sure I'll get sorted now.
Posted : 20/08/2014 11:49 am
The Superstar ones are £18 for one size, so price mounts up if you have many sizes. Plus not a blind bearing puller?
Posted : 20/08/2014 12:50 pm
