BB386 bottom bracke...
BB386 bottom bracket supplier?
[#13518631]
Need a new BB386 for the cross bike (vitus energie, shimano crankset). Anyone sourced one of these recently - seems to be slim pickings in the UK?
Had a token one before which had quite a nice design of screwing together, but can't see them available anywhere other than direct from China or Taiwan.
Posted : 27/01/2025 3:13 pm
Can't remember the details but don't you buy a more common sort and use an adapter. That's what I did last time. Vitus energies, SRAM cranks.
Posted : 27/01/2025 3:17 pm
Maybe it was a pf30 and adapter. Uber bike?
Posted : 27/01/2025 3:19 pm
Thanks both. Mister-P that is the one I was thinking of.
Uberbike do have a pf30 shimano that I think has the same cups as bb386, just the shell is narrower. So would go in ok but not sure if there would be width issues on the crankset.
Posted : 27/01/2025 3:47 pm
Lovely stuff.  I wasn't sure if 386 and 386EVO were the same thing.  So many "standards".
Posted : 27/01/2025 3:57 pm
@garry_lager
Just buy the bearings, they pop out of the shell / plastic casing with a bit of minor persuasion and then press a new pair back in,  they're 6805RS.
Just be careful with plastic GXP adapters that are in there as they're pretty fragile.
Posted : 27/01/2025 6:20 pm
Thanks Steve but I've already bolloxed the plastic cup with a screwdriver. Good advice though! Used to banging mtb ones out that cost nowt.
Posted : 27/01/2025 8:27 pm
Well that's a bit of a bugger, you could always just buy this one from eBay as that's what's in them originally and use your GXP adapters or change the bearings for the afore mentioned ones.
Posted : 28/01/2025 10:03 am
