BB30 axle converter...
[Closed] BB30 axle converters
[#8374669]
So still trying to work out what to do on my carbon scalpel.
Something like [url= https://qwertycycles.co.uk/products/bb30-pf30-24mm-reducers ]These[/url] or [url= http://www.cannondalespares.com/Wheels-Manufacturing-BBright-and-BB30A-to-Shimano-24-mm-Crank-Shims/product_detail/3-42205 ]These[/url] what are the spacers for?
Ive ordered some Rotor BB30 bearings too.
TIA
Posted : 24/02/2017 1:43 pm
What exactly are you trying to do? If its a bb30 frame you need bearings and circlips to retain the bearing the either a 30mm axle chainset and the correct spacers or the 24mm adaptors and then a 24mm chain set
If it's a pf46 frame you need the correct bb (bearings in a cup) then the same as above with the chainset
Posted : 24/02/2017 2:07 pm
 core
I think he wants to convert it to use threaded cups?
Posted : 24/02/2017 4:07 pm
https://www.praxiscycles.com/conversion-bb/
Posted : 24/02/2017 4:37 pm
As in the photo and links guys!
I can only use the bearings that sit in the cups that are bounded into the frame, I can't fit the push fit bb's for that reason and have a spare xt crank that I'd like to use instead of having to buy a bb30 crank.
So was wondering if the converters in the links were much the same and why so many spacers?
Posted : 24/02/2017 5:27 pm
[url= https://qwertycycles.co.uk/products/bb30-pf30-24mm-reducers ]this one [/url]
Or
[url= http://www.cannondalespares.com/Wheels-Manufacturing-BBright-and-BB30A-to-Shimano-24-mm-Crank-Shims/product_detail/3-42205 ]this one[/url]
And why all the shims?
Posted : 24/02/2017 6:02 pm
Any more help guys please...!
The bb30 bearings and circlips arrived today so need to decide on getting one of the converters or putting a wtd add for some bb30 cranks.
Posted : 25/02/2017 1:29 pm
cheers and do I need to use shims with those or just push them into the new bearings?
Posted : 25/02/2017 3:58 pm
Slather everything in grease.Bung em in....chuck chainset in.Job jobbed.
Posted : 25/02/2017 4:21 pm
Ta. Whats confusing me is the shims that come with those adapters
[url= http://www.cannondalespares.com/Wheels-Manufacturing-BBright-and-BB30A-to-Shimano-24-mm-Crank-Shims/product_detail/3-42205 ]Linky[/url]
Posted : 25/02/2017 7:06 pm
'BBright and BB30A Adaptors'.
Posted : 25/02/2017 7:50 pm
He's asking about the shims folks.
I didn't need any, running a Shimano chainset in a Cannondale BB30 frame.
Posted : 25/02/2017 7:51 pm
Cheers, guess they're for sorting out the chainline if needed?
Posted : 25/02/2017 10:49 pm
Rorschach sent you a msg cheers.
Posted : 02/03/2017 10:36 am
Not sure if relevant but I used a FSA BB30 Threaded Adapter a few years ago and still going strong.
Posted : 03/03/2017 10:45 am
Pretty sure on my frame the bb30 bearing cups are bonded into the bottom bracket shell, if so I can't use a push in converter.
Posted : 03/03/2017 1:18 pm
Used an FSA converter too. Like mentioned plenty of grease or copperslip or it will creak like a bas$%^&. Mine did
Posted : 03/03/2017 1:41 pm
